Results 1 to 4 of 4
Thread: turbo install question
    Default turbo install question
    1-ok got a type rs bov, it has two nipples, where they post to go?
    2-ok waste gate has two nipples, where they go one is on side an one on top ?
    3-ok got a boost controler, when I hook it up an where how would i set it to be safe to crank the motor? screw it all the way done? thanks an if any one has pics, would help, Joshua
    02 WRX patrick4588's Avatar
    warner robins
    wow....
    1)for vacuum source so it knows when to open
    2)again, for vacuum source. top is for boost controller
    3)um yeah it doesnt really matter where the boost controller is set at to start the motor. it doesnt make boost automatically. you have to get into the throttle. dont floor it and you wont see boost.
    Dec 2003
    Cant say too much for the one that cant read or just cant explain a little better, but the side one on the bov is hooked to vacuum and the side one on the wastegate connect to the turbo nipple which should be next to the charge pipe connector. As for the boost controller im not too sure about those.
    Dec 2003
    If u look at my signature pic up profile you can see my wastegate line hooked up. Hope that helps.
