Thread: WTB: LSVTEC parts...
    San Diego, CA
    Default WTB: LSVTEC parts...
    I'm not really in any rush to get these, but I'd like to go ahead and start piecing together some parts for my LSVTEC setup... As you'll see, I'm MOSTLY focused on the bottom end for right now. If you've got something for an Si head, or for an LSVTEC setup...go ahead and let me know.
    Here's the parts I'm looking for as of right now...
    Si/GSR Oil Pump - Pref new, OEM
    81 or 81.5mm oil rings - New ONLY, OEM is best...
    81 or 81.5mm pistons (PR3, P72, P75...I think those are the right codes...) - pref new, OEM ONLY!!!
    ACL bearings - New ONLY...might take some OEM hondas
    Si/GSR Water pump - Newer is better, OEM is better...
    Si/GSR Timing Belt - New ONLY, OEM is better...
    ARP rod bolts - pref new
    Parts I'll need in the future (but may pick up sooner than planned if the deal is right)...
    Si head - OBD1 pref. I might take it w/ or w/o valves, springs, cams, whatever...just depends
    GE LSVTEC Gasket Set
    ARP head studs - pref new
    ECU
    JDMadness ==> EvasiveEF9
    Southside
    I have the cams and camgears for the Si..
    I have some brand new USDM Type R rods. Brand new pistons standard size but have scratches on the sides, and wrist pins.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I have a homeboy that might have a head. I'll check on it for ya.
    San Diego, CA
    Quote Originally Posted by JDM_EK4
    If I get a head without these parts, I'll be in touch.
    Quote Originally Posted by xbn83
    Not interested in rods, but throw up some pictures of those pistons w/ scratches...
    You've got my ears.
    i got a Cometic Head Gasket 81mm
    THE MAN!! bseriesus's Avatar
    Columbus GA
    i got some I.T.R L.M.A's and inner springs,lower crank brace with bolts, dowel pins,pickup tube.all O.E.M NEW never open still in bags and boxes.
    MOJO 4 PRESIDENT !!
    check snoopy he has a shitload of ls/vtec stuff
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
