Results 1 to 5 of 5
Thread: Stereo Stuff cheap
    I drive a dodge stratus 98strat's Avatar
    Norcross
    Default Stereo Stuff cheap
    Panasonic 6.5's 3 ways and a bazooka mono amp. Speakers used for 1 year still have original box and grilles. Amp is 2 years old but was only used for a year. All in perfect working condition.
    Panasonic Cj-DA1633U
    * Type : 3-way
    * Size : 6 1/2"
    * Peak Input Power : 230W
    * Frequency Range : 30Hz - 50kHz
    * Sensitivity (S.P.L.) : 91dB/W/m
    * Nominal Impedance : 4 ohms
    * Mounting Depth : 1.909"
    * Magnet Weight : 10.0 oz
    * Typical Mounting Location : Door & rear deck
    * Tweeter Design : 1-3/8" titanium dome tweeter, 5/8" supertweeter
    * Discrete Edge Design : Yes
    * Holographic Surface Design : Yes
    * Elastomer Coated Cloth Edge : Yes
    * Ultra-Heat Resistant Voice Coil Bobbin : Yes
    * High Linearity Suspension : Yes
    * European Standard Frame Dimensions : Yes
    $30 OBO
    Bazooka ELA 300.1
    * 300rms at 2 ohm 200rms at 4 ohm
    * Power Output: 300W
    * Frequency Response: 20-250Hz
    * Fuse 60 Crossover
    * Protection Thermal, Short Circuit, Overload
    * Max Power Output: 500W
    * Power @ 4 OHM: 300W peak
    * Power @ 2 OHM: 500W peak
    * Signal To Noise Ratio: 115
    * Battery Voltage Range 10.5-14.4 volt
    * Bass EQ
    * Remote Control optional
    $70 OBO
    Tsunami Capacitor 1 Farad Digital top
    All chrome sticker removed
    $ 40 OBO
    Pioneer GEX-P900XM
    Old pioneer xm unit. Missing power cable and antenna. Only have a short IP-bus cable. Only displays 8 characters of text
    $10 OBO
    I can get pics by tomorrow of everything but the amp which is the only item over $50 has a picture so i guess i should be okay with the mod. If there is a problem let me know and i'll get them up tonight.
    Attached Thumbnails Attached Thumbnails -amp1-jpg   -amp2-jpg
    Norcross
    BUMP
    Norcross
    Blacc Panther member
    look to ya left
    like the amp and the door speakers
    Norcross
    Nice Good Luck
