- Ka24det Swap
- Rep Power
- 21
Ka24det Swap
Setup:
-Shot pinned rods
-Supertech .30 pistons
-Boost designs manifold
-Everything all the way down to put it in a single cam car (harness, Ecu)
-Engine harness
-SAFC
-Greddy Spec 1 Boost controller
-HKS front mount (banged up some but works fine)
-RFL Blow-off valve
-5-Speed transmission
-One piece driveshaft
-Aluminum intercooler piping with AN fittings for the PCV vent and for the Idle air control vent and all couplers
-Brand new just put in Compition Clutch stage 4 with less than 1 mile on it
-Head was just done with new exhaust guides and three angle valve job
-Garrett T3/T4 turbo with a .50 A/R has 8,000 miles on it (no shaft play or anything) Internal wastegate
Motor has a slit knock so it needs to be rebearinged before anyone does anything with it.
Looking around $2500 for everything but shoot me some offers
I might be forgetting a few things so I will update the list as I remember
- Ka24det Swap
- You may not post replies
- You may not edit your posts
Forum Rules
