Thread: No pressure when applying the clutch
    Default No pressure when applying the clutch
    I let a friend drive my car to the gas station and he done fucked up my car. At first it seemed like he burned the clutch out, but every day since the night I let him drive the car, the pressure when applying the clutch decreases.
    Everytime I start the car up, I have to "pump" the clutch to get some pressure. So with this, I know that something must be leaking. My guess is the master cylynder for the clutch is leaking. Any other possibilites?
    If it is just the clutch master cylinder, is it a possible DIY job for a weekend?
    your moms house
    what kind of car?
    FUCK B&D COMMUNICATIONS!
    JJSPEC Racing
    hope its not a dsm, they tend to leak into the car itself, procrastinating on fixing a problem + leaking into the car = sucks for you
    -2001 Lexus IS300
    i got the same problem right now except mine is so bad that it doesnt build up any pressure at all when i pump and the car is stuck in neutral. mine is my slave cylinder not the master.
    Its is a Honda I have the master cylinder and the slave cylinder PM me.
    Quote Originally Posted by plv
    Mines at that point now, had to go pick up a rental today.
    Car is a 94 honda civic si
    Senior Member jfman's Avatar
    New master and get a new slave while your at it. The slave is super cheap.
    have you tried bleeding the slave
    Sounds like the clutch master cylinder. It takes about 10 min to uninstall and re install. Then about 3-5 mind to bleed the clutch. No need for slave cylinder if its not bad, the new master cylinder will not have enough pressure to break your old slave cylinder.
    check to see if your clutch pedal is a little juicy, the inner seal on the master cylinder does go out and get it in the car, pull back the carpet and see if its wet. Just remember while changing the shit brake fluid WILL mess up your paint.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
