Results 1 to 22 of 22
Thread: my system
    Senior Member JASONBALL's Avatar
    columbus GA
    Default system ( make a deal)
    Here is my system up for sale. Has about 10 hours of play time. Delivery can be worked out. Meet up like half way. cheaper than shipping. if you buy multiple I will make a deal.
    3x 10in subs. 50 per sub. $90x2 125x3
    10” PEARL WHITE SUBWOOFER
    ONE-PIECE SEAMLESS POLY PROPYLENE CONE
    OVERSIZED RUBBER SURROUND
    SILVER DIE CAST BASKET,
    HEAVY DUTY CHROME PUSH TERMINALS
    BUMPED & VENTED CHROME T-YOLK
    2” DUAL KAPTON VOICE COIL
    50 OZ STRONTIUM MAGNET
    4 OHMS
    FREQ. RES: 31 HZ – 1.5 KHZ
    SENSITIVITY: 90 DB/W (1M)
    2x sub amps $100each
    MAB-901 retail $160
    1900 WATT MONOBLOCK HIGH POWER MOSFET AMPLIFIER
    1900 WATT DYNAMIC POWER @ 14.4 VOLTS
    950 WATTS X 1 @ 2 OHM
    600 WATTS X 1 @ 4 OHM
    S/N RATIO >90 DB
    REMOTE BASS BOOST CONTROL
    QSINK TECHNOLOGY (HEAT MANAGEMENT SYSTEM)
    MULTI FUNCTION VFD PANEL DISPLAYS: VOLTAGE/TEMPERATURE/AUDIO LEVEL
    BOARD MOUNTED TEMPERATURE SENSOR • HIGH FLOW COOLING FAN
    CONTINUOUSLY VARIABLE PHASE ADJUSTMENT
    LINE OUTPUT FOR MULTIPLE AMPLIFIER SYSTEMS
    VARIABLE INPUT LEVEL 5V TO 0.2V
    BUILT IN ELECTRONIC CROSSOVERS
    12DB VARIABLE BASS BOOST @ 45 HZ
    ON BOARD SUB SONIC FILTER 15HZ – 55HZ
    ON BOARD LOW PASS FILTER 40HZ – 150HZ
    ELECTRONIC OVERLOAD PROTECTION
    19"L x 10.25"W x 2"D
    12 lbs.
    1x mids and highs amp $100
    MAB-944 New retail 139
    1000 WATT 4 CHANNEL MOSFET CLASS AB AMPLIFIER
    500 WATTS DYNAMIC X 2 BRIDGED @ 14.4 VOLTS
    200 WATTS X 4 @ 2 OHM
    140 WATTS X 4 @ 4 OHM
    2 OHM STABLE • S/N RATIO >90 DB
    VARIABLE INPUT LEVEL 4.5V TO 0.2V
    BUILT IN ELECTRONIC CROSSOVERS • 15 db VARIABLE BASS BOOST
    ON BOARD HIGH PASS FILTER 60HZ – 1.2 KHZ
    ON BOARD LOW PASS FILTER 50HZ – 250 HZ
    16"L x 10"W x 2.25"D
    10 lbs.
    Amp Rack $250
    Sub enclosure $500
    Hatch wrap $150
    Blacc Panther member
    look to ya left
    real nice
    columbus GA
    columbus GA
    really looking to get rid of this stuff.
    Certified Gearhead ion07's Avatar
    damm nice.. gl with the sale
    columbus GA
    appreciate it bro
    blank
    nowhere
    hmm
    how good is this stuff.
    what can you do for me with
    2 10s
    1 sub amp
    1 4 channel
    columbus GA
    Quote Originally Posted by Bucky
    hmm
    2 10s
    1 sub amp
    1 4 channel
    check your PM's
    columbus GA
    bumps
    columbus GA
    Gangstaaah
    Dacula / Athens
    looks super clean
    columbus GA
    thanks
    Suwanee/Dahlonega/ Miami Beach
    pm me a price for the subs box and amp. go in a grand cherokee?
    columbus GA
    sub box and the amp rack? I will hit you up when I get home from work.
    columbus GA
    bump want to get rid of this. lets deal
    Certified Gearhead gobraves00's Avatar
    dallas, ga
    what u gonna do with car once all gone
    look to ya left
    i want a amp
    columbus GA
    check your pms bro
    Newnan
    might have a friend who wants 2 10's and an amp pm me if still available
    yo im checking if you are still interested in the possible trade for my subs for your amp
    columbus GA
    check your PMs
    columbus GA
