Results 1 to 21 of 21
Thread: RUF CTR3
    Macon
    Default RUF CTR3
    Check out the 07 RUF CTR3. Looks like it is based on an old Carrera GT1 Chassis.
    Body
    Body build in steel, aluminium and kevlar-carbon.
    Rollover protection in A-pillar and in birdcage.
    The birdcage forms a torsion resistant unit with the front chassis by joining to the sill beam and the A pillar.
    Front structure: steel, zinc dipped
    Safety passenger compartment: steel, zinc dipped
    Engine and transmission frame: space frame and birdcage
    Front bonnet and doors: aluminium
    Body shell: Kevlar-Carbon composite
    Engine
    Type: turbocharged boxer
    Cylinders: 6
    Displacement: 3,746 cc / 228.6 in3
    Bore: 102 mm / 4.01 in
    Stroke: 76.4 mm / 3.01 in
    Output: 515 kW (700 hp) at 7,000 rpm
    Max. torque: 890 Nm / 656.5 lb-ft
    Compression ratio: 9.2 : 1
    Engine control unit: Bosch Motronic with OBD-2
    Turbo charger: two KKK turbo chargers
    Intercooler: two air-air-intercoolers
    Transmission
    Power delivery: Limited slip differential
    Transmission: Locking value load/deceleration
    Rear wheel drive
    Sequential 6-speed-manual transmission, transversal, angle drive, shift indicator in the instrument panel
    Multi-disc locking differential
    40 % / 60 %
    Chassis
    Front axle: McPherson struts, anti-roll bar
    Rear axle: Multilink rear axle, anti-roll bar horizontal coil over shock absorbers
    Power assisted rack and pinion
    Steering
    Brakes
    Brake callipers front/rear: 6 piston fixed light alloy callipers
    Brake discs front/rear: ventilated and cross drilled ceramic composite discs
    Brake disc diameter front/rear: 380 mm / 15 in / 380 mm / 15 in
    Anti-lock braking system: Bosch ABS 8.0
    Wheels and Tyres
    Wheels front/rear: 8.5” x 19 / 12.5” x 20
    Tyres front/ rear: 255/35 ZR 19 / 335/30 ZR 20
    Size and weights
    Length: 4,445 mm / 175.0 in
    Width: 1,944 mm / 76.5 in
    Height: 1,200 mm / 47.2 in
    Wheelbase: 2,625 mm / 103.3 in
    Front track: 1,506 mm / 59.3 in
    Rear track: 1,585 mm / 62.4 in
    Empty weight with 6 speed manual transmission
    According to DIN: 1,400 kg / 3,086.4 lbs
    According to EG-standards: 1,475 kg / 3,251.8 lbs
    Performance
    Top speed: 375 kph / 235 mph
    0-100 kph / 0 – 62 mph: 3.2 sec
    Price
    Euro 380,000.00 ($510,000)
    Land Rover LR3 HSE
    Macon
    check out RUF's other models
    http://www.rufautocentre.com/index.asp
    Land Rover LR3 HSE
    wrong....based off the Cayman which is the 987 chassis.
    Macon
    yea I thought the chassis lines were similar, but I could not figure out why it would cost 10 times as much as the cayman if it was based on the cayman chassis.... I guess the extra $460000 is in the engine and body work...
    Land Rover LR3 HSE
    Macon
    I wonder how the wheelbase is so much longer on this car though. The cayman is 2415mm long, and this one is 2625, 210mm longer. thats about 9 inches or so.
    Land Rover LR3 HSE
    you can stretch a wheelbase
    BOOB koukis14's Avatar
    Pennsyltucky
    I like the Carrera GT based one that goes 250mph.
    Young'n go ahead & trade in your Cayman for one ..
    Dunwoody/Sandy Springs
    thats hott
    Quote Originally Posted by koukis14
    Road and Track? That top speed is an estimate of the twin turbo version, not the N/A.
    Macon
    Quote Originally Posted by The Youngn
    not withough extensive reengineering. This car may have started from the cayman design, but now it is a completely different car. it has a wider track, longer wheelbase, and the roof is lower. the only thing cayman about it is the tail lights. the front end looks to be from a 997.
    Land Rover LR3 HSE
    Sorry guys its Ruf's very own chassis.
    Here ya go
    Attached Thumbnails Attached Thumbnails -ctr3_8-jpg   -ctr3_9-jpg   -ctr37hp9-jpg
    Attached Thumbnails Attached Thumbnails -bahraininvitationab1-jpg
    All bark, no bite.
    Wrong. The front is a Porsche 997 from the A pillar forward. The entire backhalf is completely Ruf built and fabricated. They were going to build the car from the ground up but it proved to be too expensive. Hence the longer wheelbase and width.
    Nobody ever listens to poor ol'e 81911.
    Pennsyltucky
    Quote Originally Posted by 81911
    And I wan't one.
    Quote Originally Posted by KevinT707
    Yes sir!
    Quote Originally Posted by allmotoronly
    Thats what RUF does to cars and i know the front end is from a 997. I can put a 997 front on my car cuz putting that on my car would be like putting an SI front on a 97 EK
    Quote Originally Posted by iloveboost
    same as said to allmotor guy....
    Macon
    Ok I'm calling ruf today to figure this out
    Land Rover LR3 HSE
    All bark, no bite.
    The rear end is not from the Cayman. I think the tails are Cayman but the structure underneath the carbon fiber panels are not.
    The rear end is Ruf's own.
