Results 1 to 4 of 4
Thread: Acura & Honda Parts BLOW OUT!! B16 B18
    Default Acura & Honda Parts BLOW OUT!! B16 B18
    Here is a List of Honda & Acura parts that I have left from my used auto parts shop.
    All parts are USED and are in GOOD to ALMOST NEW CONDITION!!!!!!!!!
    *****************$400 for everything **************************
    1. B Series Front Tranny Mount
    2. B Series Left Front (lower) Mount
    3. B16 Rods (set of 4)
    4. 92-95 Civic Clutch Master Cylinder and Slave Cyl
    5. 92-95 Civic Brake Master Cylinder
    6. B16 SiR II Fuel Injectors
    7. B16 (99 SI) Intake Manifold
    8. B18c (99 GSR) Fuel Injectors OBDII (with plugs)
    9. 92 Civic Rack-in-Pinion with tie rods
    10. 99 GSR Rack-in-Pinion with tie rods
    11. B16 Crank (2 in All with less than 40k)
    12. 99 GSR Hood Latch & Hinges
    13. 94 LS Fuel Rail
    14. B Series IAC Valve OBDI
    15. B16 Block (BARE & NEEDS NO WORK) #1405573
    16. B16 Rear seal
    17. B16 Oil Pump
    18. B16 Water Pump
    19. B18b Water Pump
    20. 94 Accord Head Lamps (pair)
    21. 92-95 Black outer Window Trim
    22. 95 Civic Radio Trim
    23. 92 Civic Hatch Wing (teal green)
    24. 92 Civic Lower Control Arms
    25. 94 Integra Upper Control Arms
    26. OBD II OUTTER FUSE BOX (with all relays and fuses)
    27. 98 Civic ECU (D16y8)
    28. 89 Integra ECU (5Spd)
    29. 94 Integra Climate Control
    30. 92-99 Civic drivers side air bag.
    31. 90 Acura Legend Drivers Side Air bag
    32. 92 Lexus Es 300 Drivers Side air bag
    33. 93 Accord Drivers Side air bag
    1993 JDM INTEGRA GSR STOCK (FACTORY) TAPE/EQ/6 DISC CHANGER.
    ***THESE ARE USED AUTO PARTS**** All Parts WORK & are in VERY GOOD Shape.
    Please send all Questions to [email protected]
    Attached Thumbnails Attached Thumbnails -007_7-jpg   -023_23-jpg   -028_28-jpg   -034_34-jpg   -093_93-jpg
    140 on one wheel
    columbus, ga
    i have $20 for this and ill pick it up matt.
    shoot me your #
    Slow... mp5o's Avatar
    Call me early 2mrw to meet up for the brake cables and etc. I still need em! 770-380-4295.
