Thread: Leupold Vari-X III Rifle Scope *USED*
    Norfolk, VA
    Default Leupold Vari-X III Rifle Scope *USED*
    3.5-10x50mm
    Leupold has pushed the envelope in every direction...structural design, optics, construction...to give you a better scope, one that's a worthy replacement for the Vari-X III. Everything you demand from an American-made scope, such as legendary Leupold ruggedness, absolute waterproof integrity, and the Leupold Full Lifetime Guarantee is there, but it's the refinements that make the VX-III the most exciting Leupold in years.
    Finger-adjustable windage and elevation dials with resettable pointer dials, marking the zero point. Lockable, fast-focus eyepiece so you can securely lock the eyepiece once you've set your reticle focus. Side focus parallax adjustment is standard on most models, so you can easily focus from any shooting position. Index Matched Lens System. Leupold users know that for a bright, crisp sight picture with good contrast in all light conditions, proper light management and maximum light transmission is absolutely critical. Here's how the Leupold Index Matched Lens System works: Leupold engineers specified very low reflection of light at several key points across the range of colors that the human eye can see. Light that doesn't reflect off the lens surfaces transmits through and contributes to a crisp, true-colored and brilliant image. The light that is transmitted does not bounce around inside the scope, causing glare that can degrade the contrast you want. Since dozens of different glass types are available to create a lens system that gives you the optical performance you need, the lens technicians has to pick just the right coating material for each individual lens surface, in order to meet the stringent specifications established by their technical team. They also matched the ideal coating materials to each lens' glass type and layered these different substances to minimize reflections and maximize performance. The result? Some of the VX-III riflescopes have measured as high as 98% TOTAL light transmission, which means you'll get brightness and clarity like you've never seen before.
    Poor and need cash $400.00 obo
    <---Click it.
    Norfolk, VA
    if you want to know why its expensive check this out first http://www.wholesalehunter.com/produ...XIIIScopes.htm
    <---Click it.
    Norfolk, VA
    ttt
    <---Click it.
    ZOMG ChnkyLao's Avatar
    Winder, GA
    damn, gl with sale
    Norfolk, VA
    thanks
    <---Click it.
    Certified Gearhead Nissangeek's Avatar
    Smyrna
    Thats a damn good deal. I've seen Leupolds for a grand or more.
    Norcross
    Man People On IA Broke HAAHH Good Luck
    Bump
    Norfolk, VA
    thanks
    <---Click it.
