Results 1 to 11 of 11
Thread: Airbags.
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    Default Airbags.
    Is it theoretically possible to install airbags in ANY car, even if it didn't come with them?
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    its theoretically possible to do almost anything
    Dining in Hell
    Okay. Well, generally speaking, could it be done?
    sure! you can also put a fucking rocket on any car and send it to the moon!
    Dining in Hell
    Wow, thanks a lot.
    I need more cowbell! wes_297's Avatar
    Jasper,Ga
    im going to assume you mean airbags as in a air ride. if so then yes you can put airbags on anything. if not then i dont know
    Senior Member BlkCD5's Avatar
    I"d rather not have airbags. Have you ever been in a wreck and have them blow up in your face? You'd understand my reasoning then. It could probably be done, but you'd go through so much shit to do it.
    JDM TYTE AnthonyF's Avatar
    yes but why to both ?'s
    if u have a slammed truck airbags are good. If you have a hatch airbags bad.
    if u want steering air bags....y? drive safer. it's cheaper
    The Carbon Fibered R6
    Dining in Hell
    yup.
    steering airbags.
    But I don't care at this point.
    Senior Member jfman's Avatar
    You would have to wire up a whole SRS system. All the sensors, the clock spring, the SRS unit. + Find a safe way to mount the airbags. It would be a nightmare. The SRS sensors are calibrated for a particular chassis and wouls be out of spec in another car.
    Its going to be hell
    Quote Originally Posted by jfman
