Thread: Help ! 99 civic help
    Certified Gearhead JDMef88's Avatar
    Gainsville, GA
    Default Help ! 99 civic help
    Ok so iv posted couple days back, about thinking my main relay was bad...well replaced the main relay in my 1999 civic cause sometimes my car would run, then would die, then let it like "chill out" for awhile it would run, then it would shut off in really bad places when i drove for awhile, all power on, just no motor, then i would try and turn it on and it would not crank over, like there was no fule. Replaced the fuel pump after it had been sitting for 3 days, woo it worked, drove it 3 miles and it broke down in the same exact spot it had before, leaving me stranded...i give up, new fuel pump...new main realy, ohh and new fuel filter. Wont do it, sometimes i can get it to come on, then it just dies and main relay starts clicking like 5 times...maby electricity....i have no clue and i need help- gas in in the fuel lines, its getting there, i can turn the key, gas shoots out of the lines, just wont turn over, like no explsion in the motor. My last try, got some sparkplugs, if it dont work goign to spend 300$ to get it fixed gimmy some anwsers peeps!
    What is it? New dizzy? new plugs? i need help!
    Wtb 96-00 civic aftermarket struts asap
    San antonio 210
    maybe a sensor.. or wire harness
    IDK but gl on it bro
    MaD Tyte y0! ek forever's Avatar
    carrollton
    Have you checked the grounds? Or your battery terminals might be loose.
    Valdosta,GA
    bump bc that shit is the suck and you need help
    LAWRENCEVILLE
    checked the ignition coil in the dizzy? some time they work untill they get heated up.
    JJSPEC Racing
    Quote Originally Posted by silversol
    my exact thoughts, ive dealt with this problem a few times, def sounds like a dist related problem
    -2001 Lexus IS300
