Results 1 to 33 of 33
Thread: removing wheel studs honda
    blank
    nowhere
    Default removing wheel studs honda
    anyone ever removed the wheels studs from the front an EK. will i really have to take the spindle to a machine shop?
    Just another ricer
    Pennsyl-fuckin-tucky ya'll
    Are you saving them? or replacing them?? I beat mine out with a hammer to put new ones in. Pretty sure if you turn it to the righht spot or something like that, they'll come all the way out.
    90% of teens say "oh shit" before a wreck. The other 10% are from Pennsylvania, they say " hold my beer and watch this shit."
    EvasiveEF9: Just fill me in...if it's black, I'm all over it...
    Sure will
    Quote Originally Posted by mxglory258
    blank
    nowhere
    usually they have a spot groved out where you can knock it out. but i cant find a spot on mine. there is no space behind to knock it out. it hits the hub. and its already broken so i know putting the good one back in wont work
    bite it
    Just another ricer
    Quote Originally Posted by Bucky
    4" grinder, Make one. Shouldn't take much.
    Super Handling
    96-00 Civics are really complicated with that. From what I heard, you'll need to press it out, dissemble, reassemble, and press back in. Some shops who have had experience in replacing 96-00 Civic studs quoted me over 150. My cousin says he'll fix mine on Sunday, I'll see if I can help you if you still need it then.
    blank
    nowhere
    more than likely i will still need help. i have done many studs before just this one is weird
    check my art skills
    I usually press the hub out when I do them at the shop, takes a little time. But much easier in the long run.
    Super Handling
    check my art skills
    Lol, that's pretty accurate, I don't know why, but so many Civics have their front passenger studs broken. I even tried a slide hammer, no luck, like on Honda-tech. I'll leave it to my cousin, he hasn't let me down before.
    warner robins
    i used a slide hammer and pulled the hub off. then you hammer out the studs and hammer in the new ones. i rented my slide hammer at autozone for like $40
    JJSPEC.COM
    blank
    nowhere
    i might try the slide hammer how did you get it back on?
    Super Handling
    Quote Originally Posted by d16_turbo
    I tried a slide hammer, it doesn't work, it apparently works for 92-95 Civics and 94-01 Integras, but not 96-00 Civics.
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    yeah, newer civics you have to take the hub off and have the bearings pressed back in.. BUT...if you take a grinder and grind half the flat part off the stud, you hace just knock it out.
    blank
    nowhere
    i have to get a new one back in though
    warner robins
    i didnt think 92-95 was different from 96-00
    JJSPEC.COM
    No
    LIRL. I was going to bring that up.
    your moms house
    Quote Originally Posted by RobbieDB
    haha me too
    FUCK B&D COMMUNICATIONS!
    Super Handling
    Hey, my cousin fixed my broken stud problem today. What he did was exactly just like the thread on Honda-tech. Sorry, but I do not have the link. What you would have to do different is use a much bigger slide hammer, the one at Autozone will not do. The one he used was about 3 feet long and much heavier. The only tricky part is putting it back in. But if you have air tools, it should be no problem. LMK if you have questions. That shit was pissing me off too.
    one time i ripped the splines in the hub and the lugnut was still attached...so the stud was freely spinning with lug nut attached! sorry had to share my crazy experience..
    Quote Originally Posted by TypeRPersonality
    Did you replace the bearings or just put the old one back in?
    Quote Originally Posted by BenefitX
    Had two ARP lugs strip out in the hub with the lugs on...it's a MAJOR bitch to get off when that happens Only took about 30 minutes to take the entire spindle off and good ole Autofab assisted me with jamming a pry bar between the hub and spindle then use their impact to snatch the lugs.
    On the later model hubs there is a circlip on there that prevents it from coming out, most people don't realize it
    how is autofab? never been there but they are close to me , im having problems getting power to my starter. i Pmed them
    Give them a call during business hours tomorrow -- their website is in my sig. Ask for Thomas, tell him i sent ya
    blank
    nowhere
    i tried to get them to do some exhaust work for me but they never got back to me. went up there for a quote and everything. but never got that call. i am sure it was a one time situation.
    Super Handling
    I just had the same bearings placed back in, is anything wrong with that?
    yeah, you'll probably be pulling it back apart and replacing it pretty soon naw, it may work fine but normally they don't cooperate once being pulled apart and put back in -- it might be weeks or months before a vibration is noticed...then you have about 50 miles to go before you're rockin -4° camber and more broken studs
    Super Handling
    Thanks for the heads up. If I do note vibration and camber, I'll have the bearings replaced then.
    superduper LLLLLLLLL
    take it to vuongy_dong bucky! lol
    blank
    nowhere
    he lives south of atl now right?
    The camber won't show until the bearing issue gets severe -- that's when your hub is about to come apart
    he lives 5 mins away from BP in duluth
    blank
    nowhere
    oh ok. can he do it
    yeah, PM vuong_dong
