Results 1 to 10 of 10
Thread: Need help with a B16 Swap
    IA Member JDMJorgie's Avatar
    Dalton, Ga
    Question Need help with a B16 Swap
    I know it sounds shitty but does anyone know if a 97 civic dx transmission can bolt up to a 99 USDM B16 motor I am also a newb to this forum.
    your moms house
    wont work. D wont bolt to B
    FUCK B&D COMMUNICATIONS!
    Dalton, Ga
    But I know a guy with an LX tranny bolted to a B16 and its a D series
    Not possible sir. MOST if not ALL B-Series parts will interchange; then D-Series goes the same way.
    Then there's also Cable & Hydraulic trannys also.
    Dalton, Ga
    The B16 does have a hydraulic transmission. In case you didn't know both the the Si, Dx, and Lx models have shift linkages thus hydraulic. Cars like the integra and prelude have cable operated transmissions. My question is not if it will work. My question if it will bolt up.
    Southside
    Quote Originally Posted by JDMJorgie
    The Answer is No
    Yes, I know 99-00 Si have Hydro Trans. BTW, shift linkages have nothing to do with what makes it either Cable or Hydro. FYI, 94+ Integras all have Hydro Trans. And NO it will not bolt up foo.
    Just another ricer
    Pennsyl-fuckin-tucky ya'll
    I looked into the same shit before, but looking for gas mileage b/c the D series trans seemed to have an airplane gear for 5th. lol. I'm looking to find a trans for my B16, that'll have 1-4 the same as what they are now, or roughly close, then have a high speed 5th gear for low RPM's on the highway.
    90% of teens say "oh shit" before a wreck. The other 10% are from Pennsylvania, they say " hold my beer and watch this shit."
    EvasiveEF9: Just fill me in...if it's black, I'm all over it...
    the bellhousing bolt patterns are completely different between a d-series and b-series. it wont work without an adapter plate of some sort that i dont believe exists and probably never will
    Macon
    Quote Originally Posted by mxglory258
    just use a LS 5th gear in a gsr/type r tranny... 5th gear in a ls is .714, gsr is .787, type r is .848. the jdm ITR uses the same 5th gear as the LS, but the jdm type r has a fd of 4.785, where the LS has a fd of 4.266. the usdm type r has a fd of 4.400, same as GSR.
    heres a link to some specs
    http://www.ff-squad.com/tech/temp/Bgears.htm
    Land Rover LR3 HSE
