Results 1 to 40 of 50
Thread: FS / FT: 1991 Toyota MR2 Turbo w/ Bad Block + Spare Block + Mods!
    NalleyToyota Manager ct9a gsr's Avatar
    Kennesaw, Ga
    Thumbs up FS / FT: 1991 Toyota MR2 Turbo w/ Bad Block + Spare Block + Mods!
    Make: Toyota
    Model: MR2 Turbo
    Year: 1991
    Chassis Mileage: 145,xxx
    Motor Mileage: 35,xxx
    Engine: JDM Celica GT4 3SGTE Turbo Motor
    VIN#: For Serious Buyers Only
    Title: 100% Clean Title
    Performance Modifications:
    - 1994 LSD Transmission (NO GRINDS, Great Gearing!)
    - APEXI N1 Exhaust
    - RACETEP 3" Downpipe
    - Test Pipe
    - Centerforce Stage 1 Clutch Kit
    - HKS BOV & Flange
    - Top-Mount Intercooler
    - HKS Intake Adapter
    - 1994 MAF Sensor
    - Port & Polished Intake Manifold w/ TVIS Delete
    - 3" Custom Intake
    - Thermostatic Temp Control (for fans)
    - NGK Laser Platinum Plugs
    - Blue Ground Wire Kit
    - Ported Throttle Body
    Mods Installed @ 130,xxx miles:
    - Newly Rebuilt Stock CT26 Turbo
    - New Alternator
    - New CV Shafts
    - New Spal 10" Fans
    - New GM Knock Sensor Upgrade
    - New Starter
    - New Battery
    - New Toyotal Timing Belt
    - New Water Pump
    - New Throwout bearing
    - New Twos R Us Brass Shifter Bushings
    - New Oil Pan Gasket
    - New Valve Cover Gasket
    - New Distributor Cap
    - New Coils
    - New Igniter
    - New Intake Manifold Gasket
    - New Exhaust Manifold Gasket
    - New Turbo Gasket
    - New Rotor Button
    Suspension Mods:
    - R1 Drilled & Slotted Rotors
    - TEIN Lowering Springs
    - Bendix Titanium Brake Pads (all around)
    Exterior Mods:
    - 16 x 7.5 Silver Fittipaldi Polaris Wheels
    - 205/40/16 Dunlop 9000 Front Tires
    - 225/45/16 Dunlop 9000 Rear Tires
    - RayBrig H4 Headlight Conversion
    - Eribuni Rear Side Engine Vents (not installed but will come w/ car)
    Interior Mods:
    - HKS EVC Boost Controller (Mounted in Center Console) Activated By Switch
    - Isotta Black Steering Wheel
    - Sparco Chrome Center Ring
    - Sparco Steering Wheel Hub
    - HKS Turbo Timer II
    - HKS Turbo Timer Harness
    - Old School Sony CD Player (Plays CDs Great, but AM/FM isnt to clear)
    - Black Leather Shift Boot
    - Megan Racing Short Throw Shifter With Lowering Plate
    - FAZE Reverse Indiglo Boost Gauge (In Dash)
    - FAZE Air Fuel Ratio Gauge
    - FAZE Single Pillar Gauge Pod
    - Reverse Indiglo Gauges
    - Carbon Fiber Gauge Cluster Bezel
    - Stainless Steel Switches, Custom Aluminum Brackets and Push Buttons
    - Quest Aluminum Pedals
    - Power Windows & Power Locks
    - Black on Black Leather
    Problems / Issues:
    - Crank is locked up and will not turn... assumed to be a bent rod
    - Paint has several imperfections (uneven pits and waves in sanding) when looked at up close... mostly on the hood which a CF hood should fix
    - Door has a couple of dings, nothing major or not typical of a 16yr old car
    - I'm not sure how the in-dash switches are wired up, sorry
    - 16yr old OEM leather driver seat has cracks
    - Needs a shift knob
    - Driver's side mirror is cracked
    THE CAR WILL COME WITH A SPARE 3SGTE SHORTBLOCK
    The car is was originaly a turbo model and the OEM motor was swapped out with the All-Trac GT4 3SGTE by a previous owner. The motor is the JDM Celica All-Trac GT4 version of the 3SGTE. The difference is in the compression (8.5:1 instead of 9.0:1 like others), the camshafts (something about the duration?), and none of the emission crap like EGR or extra sensors (Oil Level, Crank Angle). The car ran a 12.92 @ 111mph spinning in 1st and 2nd gear by a previous owner on the stock turbo @ 15psi w/ the top mount intercooler. This car beat my Evo from a roll when I had around 300whp. Factory MR2 fuel, ignition, and motors are built to hold 300+ horsepower without any upgrade. Factory injectors are 440cc and there have seen well over 400+ horsepower on bone stock blocks.
    I purchased this car from a personal friend of mine with intentions to get it up and running to use as a daily driver. However, I've lost interest and do not have the time to get this car up and running. I am in need of a daily driver... the sooner the better, hence why this project is up for sale. I bought the car knowing the block is bad however, THE CAR WILL COME WITH A SPARE 3SGTE SHORTBLOCK! Clean the block, mill the head, install new headgasket, and maybe a new oil pump (optional) and this car will be back on the road. The car is currently sitting at Mainstream Performance with the spare block and parts there as well so if you want Mainstream to do the work on the car, you don't have to worry about towing fees to there. If you want to see the car, goto Mainstream and ask to see Charles's MR2.
    Asking Price: $4,000 OR ANY TRADES, JUST PM ME!
    I will ENTERTAIN ANY/ALL TRADES THAT ARE REASONABLE! THIS INCLUDES A CAR + MONEY ON YOUR OR MY PART!
    Several Pictures:
    Video of When It Ran:
    Left-Click to Watch, Right-Click to Save (short video)
    ^_^
    www.toyotaofroswell.com
    Current: '04 S2000
    Past 700whp+ Cars: '03 Z06 | '94 Supra | '03 Evo VIII | Too Many...
    BLANK LongShot's Avatar
    Knoxville, Tn
    Seems like a great price.
    Seriously, this is a steal! Its a sunroof which is rare among mr2s. If i didnt have my black 91 turbo hardtop <-- super rare (which im V6ing btw). then i would definitley grab this up.
    bump for fellow mr2er
    No0b M0DERATOR auxiliary's Avatar
    woodstock/alpharetta
    damn I just bought a 1991 MR2 two days ago!
    That's a steal for this car!
    try www.mr2trader.com
    if you can't sell it here
    ....would you want to part anything out?
    -zen motors-
    at the shop
    trade you my pathfinder for it... well maybe. lmk if its of any interest to you.
    94 pathfinder se-v6
    108,000 miles original
    4x4
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    Quote Originally Posted by ct9a gsr
    That is a great deal :goodjob. If I was still into mr2 I would get this
    2006 Evo IX - Bolt ons
    Kennesaw, Ga
    Currently Active Users Viewing This Thread: 14 (13 members and 1 guests)
    ct9a gsr, TIGERJC, soul, 92ludevtec, AnclyT, Mleach, eddie1212, GGPIS3, m0b3atz, LongShot, banzai, Matt300ZXT, AltimaCharlie
    Something tells me this will sell quick... act fast if you want it. Cash talks. =D
    Current: '04 S2000
    Fayetteville
    if u decide to part it out, will u take 800 for the tranny
    superduper LLLLLLLLL
    should i even bother to make you an offer? haha
    Knoxville, Tn
    Could you take some better photos please. I would like to see the flaws in the paint if possible. Thats a long arse drive just to turn around and come back home with out a new car
    Its happend a few times before
    Thanks
    -Adam
    you should part it out...
    NOOB
    Alabama
    Hmmmm... trade...
    85 Ae86 hatch 3tc .040 over
    2005 REPSOL 1000 RR Fs/ft
    81 Starlet built 3tc N/A
    Gts/sr5 parts for sale
    Kennesaw, Ga
    If you want any part of the car, it'll be $4k and will come with a bunch of free stuff... (aka, no parting out)
    ^_^
    Current: '04 S2000
    Weekly Gwinnett/Junciton Meet
    i'd get slapped by my bank if i buy another car. Charles if this lasts (which it won't) and i get rid of one of my cars. I'd have myself a Mr2. Bump
    good price the car is gonna worth more then 8k of fix everything a 94 is rare too good luck
    its a 91..... just has the 94 LSD tranny
    Slow.
    Acworth
    Trade for my s13 charles?
    - Brit
    '93 Supra - na-t project
    Kennesaw, Ga
    Returned all PM's... thx.
    Current: '04 S2000
    Kennesaw, Ga
    Current: '04 S2000
    Kennesaw, Ga
    bumpizzle
    Current: '04 S2000
    Henry Co.
    in lamens terms, it comes with a spare motor ready to be swapped..after that you have a turbo mr2?
    OMG IS THAT Mr.Wong? justwongit's Avatar
    hey Charles wanna part the mr2 =]] i'd like to get my hands on some parts.. on that car lmk =]
    Super Dave Z U L8R's Avatar
    Roswell
    very nice car! +1 good seller
    Kennesaw, Ga
    bump!
    Current: '04 S2000
    Thats a hell of a price for that car. someone better jump this fast.
    Though whoever mounted that monster tach on the pillar should have their good sense card revoked for life.
    Garage-Sixgun
    hey hey now lets not rag on my craftsmanship....I was transitioning from my "early 16 year old ricer form" LOL Charles I sent oyu a PM about it I want her back!
    The stock tach just seemed way off sometimes, typical for any stock tach hence the autometer.
    Kennesaw, Ga
    The car doesn't have the monster tach anymore actually... hence why I didn't put it in the mods list.
    Bump for this weekend!
    Current: '04 S2000
    Canton, GA
    WOw that is a STEAL! GL with it. if you end up not being able to sell it, i'd be interested in the 3SGTE short block
    Kennesaw, Ga
    I'll sell at a discount rate if someone buys it this weekend, just PM me.
    Current: '04 S2000
    bump!
    Kennesaw, Ga
    all PM's returned
    Current: '04 S2000
    Kennesaw, Ga
    possible sale pending... but no money yet so feel free to PM me a serious offer
    Current: '04 S2000
    한 국
    nice car
    Kennesaw, Ga
    buyer backed out, price is negotiable if sold soon
    Current: '04 S2000
    Žanj-♠ ranj's Avatar
    pm sent
    Buslengths behind you
    looks good man,someone will have a great car(w/little work)
    No autobahn needed.
    Stone Mountain
    Will to trade for a 240
    im interested
    Push more than others think is Safe
    Expect
    more than others think is Possible
    Kennesaw, Ga
    car is still up for sale due to a few flaking buyers...
    again, I'll entertain any trades so let me know
    Current: '04 S2000
    DAMN IT!!! if i only had the money to swap the block!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    bump for you.... how bout i trade you my truck.... and i'll give you my soul if you fix it then give it to me... lol... gl with sale man.
    atlanta,ga
    bump for the sale.
    Is this raymonds old car? This is mike with the other black turbo.
    p.s.
    mr2's with stock injectors will start running lean when approaching the 280-300 whp level!! I once made 299whp at redline and you could see the afr start to rise above 12.0. I wasn't making a lot of tq though.
