is this any good? for a T04E turbo? the specs :
T04E Turbo Spec. Inlet 3" Outlet 2" Bearing Wet Floating Bearings Oil Inlet 1/8 NPT Oil Inlet Flange Standard T3/T4 Flange, Swaps 350 WHP Working Pressure: 25~30 PSI Compressor .50 A/R Compressor Turbine .63 A/R Turbine Compressor Wheel .57 T Compressor Wheel
Exducer: 3"
Inducer:2" Turbine Wheel Exducer: 2.2"
Inducer:2.58" Hot Side .58 5 Bolt Standard Hot Side
