Results 1 to 4 of 4
Thread: 97' Accord Check Engine Light
    Dreaming of Drifting... 240sxdreamer's Avatar
    Default 97' Accord Check Engine Light
    My check engine light came on a couple months ago so i took it to AutoZone and they hooked up the machine and they told me it was the Vehicle Speed Sensor. So i replaced the part and the then broken speedometer was working so problem fixed. Now the Check Engine light wont go off and it still reads the same problem on the diagnostic test. Please Help need to get emissions done for a tag that is two months over due
    Kennesaw, GA
    Gotta reset the light homie. unhook the battery and take out the backup fuse under the hood (7.5 amp fuse) and the ECU fuse and leave it out for about 30 seconds, replace everything and after about 200 miles, it should be reset
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Kennesaw, GA
    You live in kennesaw, if u need help, let me know
    OF*C
    i got an OBDII scanner that will erase the code. Your other friends might have one too but if you need me to erase it real quick then let me know. Bought it from AutoZone for 70 bucks
