Thread: S2 IM for a GSR
    Default S2 IM for a GSR
    Hey IA i am going to install a first generation skunk 2 intake manifold on my 94 gsr and i wanted to see if any of you guys could help me out. i did some research and some people say that i need longer studs from the head to the IM and they also said that i needed a non gsr Intake but other people say that there is no need for it does anyone have any experience and know if i need these things or not. also does anyone know where i can get the extended studs?
    IA please help any help will be rewarded with reps. THANKS IA
    Ohh yeah it would help if i had mentioned that i am going to run a Hondata or a password jdm asjet so it s thicker than the stock one so that is why i am wondering about the studs
    DC5-R
    Gwinett
    since no one wants to help you due to the fact that this can be found on numerous of sites, I'll chime in......
    I'm currently running the original skunk2 mani on my gsr right now, the gains are minimal unless you're cam'n such as ITRs for starters. Second, no you will not need new studs because of the gasket. You will however have to go buy some antifreeze/coolant lines, new tb gasket, and something to scrape off the old manifold. Also you may still use the gsr intake (I used it for about a year then finally bought another one). And last this is a 1-2 hour job at the MAX, took me 45min but thats because I've done it numerous of times even with the pro series (which doesn't make a damn difference, H-T shows gains from the new design of 0.000007 hp difference or what not. Does that help? I'll be back later to help answer your questions.
    Oh, and also using the s2 mani with the stock p72 equals your car running like garbage, trust me, the p72 was designed for secondaries (2 stage vtec) so by installing a single stage its gonna run funky. A stock p30 will help solve this problem since your car is obd1.
    BK ALL DAY
    ^^i agree with u.
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    I finally got around to putting that damn thing on there i think that the only thing that got me pissed of was the old gasket. but thanks guys!
    You are right i lost tooooo much low end with this new manifold its bad i think that i would have been better off with the OEM one right know since my car is so stock. Next problem is the ECU i am going to need that p30
    DC5-R
    Gwinett
    Quote Originally Posted by blackgsr89
    the p30 is a nice single stage ecu, basically the only stock ecu that utilizes dohc vtec as far as obd1 goes. You can always get a chipped p28 for your application which will help. My last teg I just used a p30 and it ran fine.
