Results 1 to 10 of 10
Thread: Engine mount Insert ? help please
    AKA Stock_dc2 torqlswonder's Avatar
    Default Engine mount Insert ? help please
    Alright IA Another question that i hope you guys can help me out on this one. I bought a insert kit from Prothane and i need to get the inserts in the driverside upper mount but i am haveing trouble getting it in but it is more then just an insert here are some pictures check it out:
    This is what the mount looks like without the OEM insert whic i needed to remove.
    Here is the Problem: the insert doesnt fit doe to that little sleeve on the on the inside of the actuall mount i think i need to take that sleeve out. does anyone have any ideas or has someone done this before and know what to do? PLease help
    C'mon guys im gettign desperate.
    warner robins
    put it in a vise and try to press it in just put some oil on it.
    JJSPEC.COM
    Quote Originally Posted by d16_turbo
    im going to try that tom. because im getting desperate now. thanks +1
    Unknown
    Rome, GA
    looks like you probably need a press...never really done one like that...what is the insert made of?
    If you dont have a press available use grease.
    Quote Originally Posted by aaronfelipe
    Yeah I can use a press and yeah i will try grease, oil and anything else I can think of
    And the inserts are made of polyurethane(how ever you spell that) basically really strong rubber.
    any more suggestions guys
    Mix lithium grease (comes in a metal toothpaste looking tube) and liquid graphite (used to lubricate the tumblers in a lock) 50/50 in a small cup then coat the mounting surfaces of the insert. Use it everywhere something comes into contact with the polyurethane.
    im going to have to try that tom.
