View Poll Results: Which rotors?
Voters
13. You may not vote on this poll
  • Plain
    6 46.15%
  • Drilled
    3 23.08%
  • Slotted
    4 30.77%
Thread: Which rotors to get?
    The Don TheGodfather's Avatar
    Default Which rotors to get?
    I am looking at getting new rotors for my car I'm getting in FL. So I was looking on Tirerack at the Brembos. They have drilled, slotted, and plain.
    Now after doing my own research and asking friends, I have found conflicting evidence. Some said slotted are better and drilled may crack. Another said slotted eat through pads quicker and drilled is the way to go. And one person suggested just going with the plain rotors.
    I don't know enough about brakes to make an educated descsion, so I'm looking for some help. I keep gettin different opinions.
    Thanks for the help.
    Athens/Memphis
    I voted plain... just get really good pads and you will be set.
    UGA: Everybody is laughing at us this year.
    Just another ricer
    Pennsyl-fuckin-tucky ya'll
    Depends no what your doing. Daily driving, racing etc. Me personally I'd go with slotted. They dont eat pads any faster. The edges of the slots if not already made to be, wear down very quickly.
    I've never seen drilled rotors crack either. Hell I race motocross, and am constantly on the front brakes. I've had my brakes get so hot in a race that they've locked up or quit working completely. Never had an issue with cracking rotors.
    So in all actuality money not an option, would go with slotted or drilled. However if you have enough know how, and access to the right shit, you could drill your own. I've done that as well on the old 71 nova I had.
    90% of teens say "oh shit" before a wreck. The other 10% are from Pennsylvania, they say " hold my beer and watch this shit."
    EvasiveEF9: Just fill me in...if it's black, I'm all over it...
    Thanks for the feedback guys.
    Appreciate it.
    JJSPEC Racing
    just dont buy ebc pads
    -2001 Lexus IS300
    Jan 2003
    with aesthetics out of the question - plain. why anyone would pay more to get slotted and or drilled rotors is beyond me, there's neglible, if any, upsides to them. I'd find the cheapest plain/blank rotors you can find and throw them on.
    K-Town!
    Drilled look the best!
    Quote Originally Posted by yudalicious
    Crossdrilling DOES NOT provide a cooler rotor any more than plain, when you remove mass from an object that actually increases the temperature of what is left. I have a quote from the owner of Brembo saying they are strictly for cosmetic purposes. Cross drilling was originally done because of the outgassing of the pads used after disc brakes were first designed...we don't use those pads any more. The cracking with cross drilled rotors is caused from instantaneous changes in temperature...try putting boiling water in a frozen mug or vice versa and see what happens. Going through a water puddle with crossdrilled rotors could easily cause them to do the same thing.
    Slotting cleans the surface of the pad, in a case where you've exceeded your brakes limits and have build up on the pad it is a cure. If you run the correct pad for the occasion then its no big deal and not needed.
    Gainesville
    crossed drilled and slotted FTW!!!!
    Yeah man. Fr33way's Avatar
    North OTP
    Both cross drilled and slotted rotors have less surface area than blanks. For street/spirited driving good front pads and brake fluid with a high boiling point (Ford HD fluid is comparable to Motul for MUCH less) should make for a good increase in stopping power. Stainless steel lines improve brake feel a good bit as well. It's not really clear what you expect out of your setup based on your initial post.
    Senior Member sogood's Avatar
    Athens
    I'm running slotted Brembo's and will admit it's pretty much just an aesthetic thing for me. Good pads and stainless steel lines will make more of a difference in your stopping power.
    i think you should run brakless... cause tampa is gay... no but i say get drum brakes all the way around. very good for performance
