Results 1 to 4 of 4
Thread: jdm h22a swap in 97 accord, no spark, any suggestions?
    s2k pusha
    Athens, GA
    Default jdm h22a swap in 97 accord, no spark, any suggestions?
    Just finish putting a jdm h22a from a 93' lude front clip into my friends 97 Accord EX. The engine is not wanting to start, turns over and all that but will not fire. I checked fuel pressure and thats fine and im def getting fuel into the cylinders, but i have no spark. Ive check pretty much all of the wiring and its ok, the obd2 to obd1 ecu wiring is good, the wiring for the distrubtor and all the sensors(Crank, TDC, and cyl. position)inside the dizzy are good. Also checked the wiring for the throttle position sensor and map sensor and it look right. What else could be keeping the car from getting spark? Spark plug and wires are good, the engine ran when it was in the front clip with carb cleaner. Any suggestions or help would be great. Trying to get this damn car outa my garage.
    h series
    norcross
    same thing happened to my car. there was like this factory kill switch that kept it from starting. i got oz to help me fix it. he basically just took it out and jumped the two ends. mine was located under the steering column. i'm not sure but you can check that out.
    s2k pusha
    Athens, GA
    do u know where the kill switch is at on the steering column, I looked in the helms and didnt really find anything on it.
    h series
    norcross
    pm annihilation on here and talk to him about it. hes the man when it comes to h22 accords.
