Thread: 92 240sx ka24de exhaust cam 248 dur
    SickSwapp-eR spooled's Avatar
    ATL baby
    Default 92 240sx ka24de exhaust cam 248 dur
    EDIT:
    I have a stock exhaust cam from a 1992 ka24de rwd motor. The cam is used but in good condition. Easy, inexpensive upgrade for your 95-98 s14 or Altima with this bigger duration exhaust cam. Approximately 10+hp gain depending on application. Please do the research as there are different setups to installing this cam that would give you the approriate gains for your powerband.
    $30
    Sick Swapp-eR
    Hampton, Ga
    hmmm could always use a exhaust cam on the intake side
    ATL baby
    Quote Originally Posted by Wurm
    Absolutely. Here are some specs for those interested.
    91-93 240sx ka24de
    intake cam 240 deg
    exhaust cam 248 deg
    95-98 240sx ka24de
    intake cam 232 deg
    exhaust cam 232 deg
    Sick Swapp-eR
    you do not get 20hp from switching those cams.
    ATL baby
    Quote Originally Posted by PsychoSquirl
    That is somewhat correct. I'll edit my first post.
    My dyno results gave the following on an automatic ka24de altima
    232 intake 232 exhaust - 125whp, 140ft/lbs
    248 intake 232 exhaust - 130whp, 147ft/lbs
    Now this is on an automatic so assuming you loose more with the auto transmission the gain is somewhere in the 10-15hp range. SAFC or some kind of EFI fine tuning hardware recommended.
    Sick Swapp-eR
    theres a good post on NICO about the cam swaps
    ATL baby
    Yep, here's the link for those interested. If you have a set of JWT sprokets ($140 investment) and SAFC then the gains can be greatly improved for your application ie: Turbo vs NA
    http://forums.nicoclub.com/zerothread/152578
    Sick Swapp-eR
