Thread: Who here burns chips and can tune ?
    Certified Gearhead Rage's Avatar
    Exclamation Who here burns chips and can tune ?
    Hey whats up everyone. I have a B16C1 OBD1 in my 98 EK. I need a chip burned and later on I will need a tune. Who here can do this? I just got the car running and I have the following codes:
    P72 OBD2 ECU
    7, 10, 20, 41, 54, 65
    Got ABS as well
    12, 61
    I have looked up these codes and Im starting to work on them now. I know if I chip I will get rid of most of them and the CFK will only go away if Im running a chipped ECU. The car runs good but just needs the small bugs worked out like with any swap thats done. Also I will be buying a jumper soon but should I run a P28 with the GSR swap or is the a better option? P30, OBD1 P72?
    Thanks
    Also try ScttyDB. I believe he works in conjunction with Mainstream. Heard really good things about him for the past 3 years.
    :) LiL PaKi's Avatar
    in my own lil world
    PM Annihilation
    I think ScttyDB has burned 2 chip for me before. Im looking for a GSR base map thats will over look a few sensors I dont have or need.
    Does Annihilation have a burner and or tune?
    Oct 2003
    first off you need a obd2-obd1 conversion harness and obd1 ecu
    cant chip that obd2 ecu
    p28 will be fine, but p30 or p72 obd1 will work also. you'll also need an obd2a-1 conversion harness. you can get the harness from www.boomslang.us DON'T get it anywhere else. i've seen almost a zero failure rate on his harnesses. conversely, i've seen an extremely high failure rate from the skunk2 and jdmshit conversion harnesses.
    that's a lot of codes.
    7=tps need that one fixed and calibrated corrected (.45v koeo, 4.5 koeo wot)
    10=iat need that one fixed and the iat plumbed into the intake tube or manifold for enrichments
    20=eld i can disable and you'll be ok
    41=primary o2 heater i can disable that and you'll be ok
    54=crank fluctuation need that one fixed as well
    65=secondary o2 heater isn't seen once you swap to obd1
    12=egr isn't seen on obd1
    61=primary o2 i can disable that and you'll be ok
    feel free to give me a call. i don't know if you were the guy that called today w/o leaving a number in your message, but if that was you leave me another message w/ your ph# and i'll call you back.
    Hey Scttydb411, that was me that called. I will give you a call back around lunch today. Im the one that had the 98 EX 4 door with a B16 and supercharger in it from Valdosta. I already have another conversion harness on the way and and I have a 5 speed P28.
    Thanks
