Results 1 to 2 of 2
Thread: vss problem
    Default vss problem
    i have a 91 crx with a 97 type r swap with a 1991 integra ls 5spd trans, and the speed sensor broke off my old trans when trying to get it out, will any speed sensor fit this hole? Its just a cable that goes into it, no vacuum lines ports or anything else, need quick fix so it is drivable, thanks for any info
    Quote Originally Posted by f150harleytr
    Wouldn't you want a speed sensor that goes to that particular transmission? I'd look into getting a ITR/B16 transmission anyways to get the full potential out of that engine too (LS gearing is wayyy too long)...unless you're planning to boost.
