Results 1 to 21 of 21
Thread: Need some more power for the F23A
    Default Need some more power for the F23A
    I need to get some more power for my 99 accord with the F23A engine.
    Already have cold air intake,dual catback exhaust, OBX 10.3mm sparkplug wires.
    -Just orderd some dc 4-2-1 headers, and OBX hi flow cat
    about to add a VIS- invader carbon fiber hood to lose bout 50lbs
    what are some other bolt on parts that can increase the power?
    At Home
    Search as always.... Theres plenty of mods for the Accord.. one would not be OBX... G/L
    what would u recommend besides like the obvious turbo or nitrous.?
    Kennesaw, GA
    Quote Originally Posted by 1NonlyAccord
    For starters, your loosing power w/ a DUAL catback, secondly dont waste 600 on a hood that looks like garbage and does virtually nothing for your power to weight ratio
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Quote Originally Posted by blank cd
    X2^ 600 is a third of wat u could get a h swap for!!! but if your a ricer then go 4 it
    well it technically started out with a Number1 catback single exhaust. but then i got a bodykit and it had to openings in the rear so i got the dual custom made..
    At Home
    Uhh.... Ricer... Well let me give you a piece of my mind.. on a N/A motor build...
    Basic Bolt Ons I/H/E
    Random Technology Cat
    Cam Gear
    Gude Cam Shaft
    A little Tuning A good 160whp
    IF your a little more extreme... and have a little deeper pockets then....
    Wiseco K20 pistons (86mm with 11:1 ratio)
    Crower Rods
    P&P Head
    ...and more Tuning..preferred by MSPi...A good 200whp
    ^^ur going for the obvious and basic stuff henry. 200whp doesnt do much with such a heavy car and 200 does sound a little too much for what you named. talk to me when you want to get a little more serious with ur motor henry
    to add on to what he said....
    full synthetic oil
    new intake manifold
    port and polish intake mani, head, and exhaust
    3 or 5 angle valve job
    new valves...intake and exhaust and springs
    machine and hone the block
    go back to the single exhaust
    lightened crank
    lightened flywheel
    new clutch
    dry sump lubrication
    throttle body
    if i think of more then ill post up for you.
    what about a vortex throttle spacer? and possibly a 68mm throttle body?
    Kennesaw, GA
    no. first invest in replacing your oem body panels cause that kit is creating drag
    OF*C
    OBX FTL
    At Home
    I have one of those vortex things... never used it.. want it?
    Kennesaw, GA
    Hey lemme use your throttle spacer. it should fit my car
    OF*C
    Gainesville
    i gat dat Nawz if you want sum nigga
    your severly handicapped with the F23 motor. Not very much stuff available for it, and any amount of real money you spend you wont see very good gains.
    they have a huge stroke, so revving the motor with a cam isnt a viable option.
    For the price it will cost you for an intake manifold, cam, cam gear, tuning, header, etc, your better off switching to the H22 longblock.
    you can pick up a low mileage H22 for around $900-1000. the h22 comes stock with 180whp(200hp) and they have way more mods available to them.
    dont try an reinvent the wheel, get the H motor an youll be much happier
    thank you mike....thats what i been telling my boy but maybe coming from you will make him understand
    Thats what my Org idea was going to get a complete h22 with tranny and iv found them anywhere from like $1200-$4000 for the jdm h22a with 220hp.
    i would have no problem buying a new engine, just i wouldnt kno where to go to get it installed and everything.?
    especially in the gwinnett.
    We do motorswaps (mainstreamperformance.com)
    In Gnette there are a couple of options like:
    AAP
    Mahdavi Motorsports
    H+M Motorsports
    Balanced Performance
    Senior Member 99SI's Avatar
    Jackson
    K24 w/ the ep3 5 speed would be a nice Accord swap. should see a noticeable difference and have an enormous amount of potential to grow. Especially with the new stuff that is continually coming out for the K. It's now a bit more economical to purchase used K parts since the newer stuff is coming out and people always have to get the "newest" thing.
    yea iv deff heard bout ur shop.i went to the web and looked at the price and its a lil pricey.
    and i lve like 10mins away from Mahdavi Motorsports.
    Athens/Memphis
    With regards to price, you pay for the quality work you get. I used a cheaper shop than I should have when I got my engine swap done, and almost a full year later, I am still trying to get them to fix their mistakes. The only reason I am still working with them is because of the "warranty" they provide and once they fix everything, I will be using a much better shop. A good job seems to cost a lot, but the "cheaper" ones can definitely bite you in the ass later.
    Now, this doesn't mean that expensive = good workmanship, but it means research the shops and find a one with a good reputation and experience with your particular swap.
    UGA: Everybody is laughing at us this year.
