ENGINE
-Ford Racing E Camshaft (M6250E303)(Gene Evans Ford Racing) $135.00
-Edelbrock Performer-Link Timing Chain Set (EDL-7814)(Summit) $45.00
-Ford Racing 1986-93 EFI Polished Valve Covers (Motorsport Logo)
(FMS-M6000K302)(Summit) $150.00
-Cobra Snake Logo Oil Filler Cap (mustangweekly.com) $10.00
-Steeda 8mm Plug Wires (Blue) (369-ste01)(steeda.com) $35.00
-NGK Spark Plugs (6945)(autopartsgiant.com) Ea./$1.00
-1987-93 Radiator Air Deflector (LRS-8349A)(50resto.com) $8.00
-Flex-a-lite Serpentine Flex Fan (FLX-1518)(Summit) $30.00
-Flex-a-lite Spacer and Spacer Kit (FLX-14556)(Summit) $8.00
-Steeda Blue Aluminum Radiator Bracket (070-01934)(steeda.com) $30.00
-Summit Aluminum Water Pump (SUM-313004)(Summit) $60.00
-180 Degree Thermostat For 1979-1995 5.0L (060-33508) $5.00
-5.0L Front Engine Mounts (Convertible) (Gene Evans Ford) $55.00
-155 Liters Per Hour Fuel Pump (LRS-9350A)(50resto.com) $55.00
-Crane Ignition Kit (Includes Fireball HI-6S Ignition, PS-91 Coil,
HI-6 To Ford TFI-IV Harness) (CRN-6000-6301)(Summit) $140.00
-Trunk Mount Battery Box Kit (SUM-G1200A)(Summit) $30.00
INTAKE/EXHAUST
-Trick Flow Street Heat Manifold (Black) (TFS-5151101)(Summit) $380.00
-Ford Racing 24lbs/hr Injectors (FMS24)(jdsperformance.com) $135.00
-C&L Performance 76MM Mass Air Package (24lb)(Includes 76MM unit and
custom TrueFlo cast aluminum inlet pipe) $185.00
-Densecharger Cold Air Induction (508993-7)(densecharger.com) $70.00
EXTERIOR
-GT Tail Light Lenses (Laurel Mountain Mustang) $150.00
-PIAA Super White Platinum 9004 Headlamp Bulbs $45.00
-ABC Grille for ‘79-‘93 (abcexclusive.com) $35.00
-Chrome Outside Door Handles (22404CH)(50resto.com) Ea./$8.00
-Steeda Oval Emblem (Large ’84-’93 GT/LX)(steeda.com) $5.00
-Pony Emblems (LRS-16228C/LRS-16228D)(50resto.com) Ea./$7.00
-‘79-‘93 Triple Side Stripes (N245-1)(Graphic Express) $60.00
-Small Designation Hood Blackout Decal (5.0 HO) (N317) $50.00
INTERIOR
-3Decore Blk/Gry Carbon Fiber Dash Kit (WD038A) $190.00
-Billet Pedal Kit (saleen.com) $30.00
-Auto Meter A/C Vent Gauge Pod (AUM 50100)(martelbros.com) $30.00
-Phantom Water Temperature (5832)(martelbros.com) $45.00
-Phantom Oil Pressure (5823)(martelbros.com) $30.00
-Phantom Clock (5885)(martelbros.com) $45.00
-Billet Window and Door Switch Kit (UPR Products) $40.00
-1970 Clock Panel Deluxe “Mach 1” Name Plate (Perogie) $25.00
-87-93 Billet 5-Speed Shifter Bezel (UPR Products) $90.00
-Hurst Universal T-Handle (HUR 153-0019)(martelbros.com) $10.00
-Hurst B-4 Boot/Plate (HUR 114-4580)(martelbros.com) $10.00
-Bullitt Lock Knob Set (mustangweekly.com) $10.00
-Billet Emergency Brake Handle Kit (UPR Products) $25.00
-Steeda Shoulder Pads (Black with red) (208-sbp-301-red-pr) $10.00
-Aluminum Door Sills (stangnet.com) $70.00
SUSPENSION
-Steeda Sport Spring Kit (steeda.com) $175.00
-Tokico Hi Performance Rear Shocks (steeda.com) Ea./$40.00
-Steeda Heavy Duty Quad Shocks (steeda.com) Ea./$20.00
-Saleen Rear Shock Tower Brace (saleen.com) $60.00
-Steeda Heavy Duty Upper Control Arm Kit (steeda.com) $85.00
-Steeda Aluminum Lower Control Arm Kit (4501)(steeda.com) $215.00
-Tokico Hi Performance Front Struts (steeda.com) Ea./$105.00
-Steeda Heavy Duty Replacement Rear Swaybar (steeda.com) $105.00
TRANSMISSION
-Steeda Tri-Ax Shifter (Fits Tremec 3550 & TKO) (555-7450) $175.00
