Thread: 1984 Mazda Rx7 GSL-SE
    *No_Pissed-ons!* chava_rx7's Avatar
    Braselton
    Default 1984 Mazda Rx7 GSL-SE
    Im Selling my 84 Rx7 5 speed that was my daly driver before i decided to sell it cuz i coul not get it back together. The previus owner had hit a pot hole and bent a stabilizer bar on the rear passenger side and broke the caliper off, it allso bent the axel housing where the shock mounts, i allredy replaced the housing with a new one and i have fixed the stabilizer bar two, and bought a new caliper for it. right now is not runnig because of an oil leak at the oil cooler, i also recently painted the car with one of my friends but he did not do the best job. the car got impouded onece cuz i got pulled over wit no insurence and they broke the key in the ignition, but i have the car wired up to run with switches and it starts with a push button. it has power windows both work kenwood stereo with brand new explode rear speekers, and everithing works on the car. i also was going to drop the car but only cut the rear springs.
    The car is some what modded and hears a list of what ive done:
    originaly comes with LSD
    Has brand new stage 3 clutch that i did not even finished breaking in
    Headders, and 2 1/2 inch exhaust all the way back to the cannitster
    It has an intake with the mass air flow adapter
    I also did the direct fire ignition conversion for it with two MSD blaster coils and one of the original coils for the trailing ignition
    Has brand new 10.3mm wires
    Brand new spark plugs NGK 4 prong
    The car is gutted exept in the front where the driver and passenger stay.
    Wats wrong with the car:
    one of the axels is not going in all the way back in the diff and it needs to be pushed in. Its olso leaking oil from the oil cooler, but this is fixed by getting a crush washer to put on it. the car does crank and run but cant drive due to this two problems. did not want to sell but ran out of patiense to fix thease two problems!. if i get my head back and decide to fix the problems, i will not sell the car b cause i like the car very much. The car has 191*** miles but is still runnig very strong!
    I am asking for 2,500 OBD also if bought i will give all four drill and slotted rotors brand new in box that i bought but did not install b cause i did not finish fixing, i also have the original owners manual and the repair manual will post pics soon.
    Attached Thumbnails Attached Thumbnails -image-jpg   -imag-jpg   -image008-jpg   -image007-jpg   -image005-jpg
    Quote:
    Boy, your better off doing drugs because there isn't any rehab or therapy for rotaries or boost.
    flowery branch
    you need pics man
    Rx7 Drift / EF grip Kalifornia087's Avatar
    Oakwood.
    Waaaaayyyyyyy overpriced....
    FC - Death by rotary forever
    CRX daily... Gas prices suck, i love my HF
    agreed....
    i MIGHT could get that for my MINT 84 with a 6port FI swap.
    Buslengths behind you
    yea,$2500 is a pretty good FC..idk i dont see mileage in post but with all the problems,doent sound like $2500
    Braselton
    Quote Originally Posted by Gilgamesh
    agreed....
    This Comes with a 6 port EFI engine 13B
    with the Direct fire ignition setup that i got on it its reving pas 8K no problem i havent seen were it redlines jet cuz i dont have a bigger tach to se were it redlines
