Page 1 of 7 12345 ... LastLast
Results 1 to 40 of 274
Thread: ACCORD CIVIC B16 D16 MISC. STUFF!!!
    Titties!!!
    Default ACCORD CIVIC B16 D16 MISC. STUFF!!! ECU's
    Best way to reach me is by PM or call 678-464-8021
    everything is obo, unless specified. new parts added!!!
    New parts
    I still have not done a full inventory so if it's not listed call, text or pm me and ask and i'll look around.
    OBD-1 LS Injectors- $65 for the set
    LS Drivers side Motor bracket- $30
    Del Sol seats- $100 for the pair. no rips or tears in them
    D16Y8 thermostat with temp sensor $25
    accord external coil with wire $15
    92-95 shift solnoid(auto) goes under the shifter, car wont park without it etc. $30
    D15B7 Valves $10
    D15B7 Valve springs $10
    D16Z6 Intake manifold and throttle body, all sensors, injectors, fuel rail $70
    Injector resistor box for MPFI- SOLD!!!!
    D16Z6 exhaust manifold w/O2 sensor $40
    D16Y8 alternator bracket $25
    D16Y7/Y8 back up sensor $20
    d16Y7/Y8 speed sensor-$50
    D16Z6 del sol/EG rear "T" bracket $45
    D16Z6 tranny mount( i think, im gonna post pics of all this stuff soon) $45
    D16Z6 timing belt side motor mount $ 80 FIRM!! cuz my dad's del sol may need them.
    D16Z6 passengerside mount $60, new but dirty firm on price also
    D16Y8 timing cover $35(comes with bolts as long as i have them)
    D16Y8 drivers side engine mount to block -$25
    D16Y8 head bolts $25
    D16Y7 head bolts $25
    D16Y8 thermostat w/ temp sensor $40(includes tube behind block)
    D16Y8 timing belt tensioner $20
    B16A2 Head Bolts SOLD!!!! thanks jose
    B16A2 thermostat w/tube $25
    D15B7 head Bolts $25
    88-91 drivers side fender for a 4door EF -$35
    EF- 88-91 4 speed tranny- $50
    obd2-a LS engine harness -SOLD
    B16A2 brackets- 15- 25 depending on what you need
    EF D15b clutch, used, $25
    D16y7 IACV manual $45
    Accord under dash fuse panel - $15
    Accord external coil 92 tc-18a- $25
    f22a6 timing belt, new $15
    D15b7 PVC/EGR box (goes behind the block) $25
    fuel lines for y7,z6,b7, and a couple others $15
    D16Y7 fuel rail $10
    Misc B18A1 parts, i don't have an inventory yet but i ill soon, pm me and i'll see if i have it.
    I have almost any D-series bolt you can think of, tranny to motor, starter, brackets, alt bolts, i'll just post a pic of all of them
    bolts,plugs,tranny fill plug, almost anything off a 97 sohc tranny. i have alot of misc stuff!!!! internals for d-series b7,b2, water pumps for y8,y7,b7,b2.
    also a bucket of misc bolts and other stuff fot a LS motor.
    Pictures of Misc Stuff not priced yet!!
    ok many pictures taken but there are more to come so there is some method to my madness.
    D15B7 timing cover $20
    Flywheel Cover D-series $20
    D15B2 Throttle Body for a DX. opens all the way $20
    D16Y7/Y8 front A/c bracket $35
    rear T bracket 92-95 Civic $30
    OBD-2A alternator d16y8 $50
    D16Y7/Y8 power steering pump bracket $30
    RSX Tan leather, foam, plastic levers, knobs, etc $70
    {SIZE=4]Accord parts must go, need out of storage yesterday!![/SIZE]
    Accord Parts
    F22a6 Harmonic Balancer- $20
    F22a6 crappy painted valve cover $15,(if you want it prepped and painted let me know
    F22a6- exhaust manifold, upper part- $15
    F22a6 engine harness- $40, or it maty go with the block
    CIVIC
    B-Series - i have some more stuff but no pics yet.
    B16 intake manifold obd-2 SOLD
    pr3 cam gears- $15
    D-series
    D16y8 crank fluctuation sensor- $50
    d16y8 head- SOLD!!!
    d16y7 intake manifold - Sold!!!d16y7 head-SOLD!!!!
    d16y8 injectors - $40
    d16y8 fuel rail - $15
    d16y8 power steering pump reservoir- $10
    obd-1 O2 sensor $40 (oem civic)
    d15b7/d16z6 oil pan $20
    d16y8 crank girdle $40
    d16y8 oil sump $25
    starters, alternators, a/c compressors, rods,b7, rods, b2, valve springs, water pumps, sensors will get a complete list and prices someday!!!!
    I have a wide variety of parts of d-series, so if i have not listed it pm me and i will let you know if i have it. several types of oil pans and valve covers. will update list
    Body Parts
    88-89 EF drivers side fender in great shape- $35
    88-89 EF front trim piece(under hood on top of bumper- $20
    88-89 side mirrors- SOLD!!!!
    90-91 civic front bumper- SOLD!!!!
    90-91 corners, 4dr only $10
    90-91 civic front bumper support$30
    ECU's
    obd-2a P2P- 5spd d16y8- SOLD!
    obd-2a P2E- 5spd- d16y7- $50
    obd-1 P06- auto- d15b7- SOLD!!
    obd-0-PM9- 4spd- d15b1/2 - $20
    DA Stuff
    these parts came off a 91 gs
    B18A1 cams- $30
    fog light switch-$10
    hazard switch-$5
    cruise swith-$5
    cargo cover-tan-$30
    ashtray black- $10
    As stated above i have many more misc. d- axles, mounting brackets, etc. a/c compressors.
    more stuff added, more to come
    i need to take some more pics first pm me or call 678-464-8021, chris
    i have more d and b series parts
    parts are located in winder GA, home of the high tech rednecks!!!!
    you have the thermostat housing? how much?
    Titties!!!
    Quote Originally Posted by dumpdaccord
    ????? did you see it in the pic? how much is one new???? pm me an offer.
    Titties!!!
    i don't know very much about accord motors, i know civics though
    Titties!!!
    bump it up
    Titties!!!
    new stuff added bump
    Titties!!!
    IA Member Spacenutz's Avatar
    Bonaire, Ga
    Can you send me some better pics of the seats?
    Titties!!!
    Quote Originally Posted by Spacenutz
    yes i can. give me a day or two. they are not torn and they are not perfect, but i will get you good pics and they are obo.
    Titties!!!
    check ur pms
    Titties!!!
    ttt more pics and items coming on wed.
    San Diego, CA
    Let me know if you have any of this:
    d16y8 head
    P29, PM7 Pistons
    JDMadness ==> EvasiveEF9
    IMPACT_AUTO_CLUB
    ill give u 5 bucks for th valve cover
    Titties!!!
    Quote Originally Posted by EvasiveEF9
    d16y8 head
    P29, PM7 Pistons
    check ur pm's
    Titties!!!
    Quote Originally Posted by Clipze95
    let me check with my brother. the accord stuff is his. i'll pm u later.
    Titties!!!
    Jam Spec!!
    Oct 2003
    Grayson, Ga
    bump for a good guy/seller... appreciate the help
    Titties!!!
    Quote Originally Posted by wespirl
    no problem, im gonna look for the bracket today as well.
    Titties!!!
    new parts added bump
    Titties!!!
    pm's replied bump
    your moms house
    Great person to deal with....
    Got a hydro D series SI tranny???
    FUCK B&D COMMUNICATIONS!
    Titties!!!
    Quote Originally Posted by Steveo
    i have one from a z6, del sol si, hydro, 112k miles. shifts good. i bought it from dirty octopus. we yanked it out of his sol one night.
    Titties!!!
    ttt
    Titties!!!
    someone come get this accord shit out of my storage building!!
    Titties!!!
    ttt
    your moms house
    Hit me up with a price on that tranny
    free bumpage
    Titties!!!
    ttt
    Titties!!!
    Titties!!!
    green egg's and ham sam i am
    Titties!!!
    ttt
    Titties!!!
    sale pending on p06 ecu!!! bumpity
    Better than before 'chell's Avatar
    Hilton Head Island
    ac bracket for a 92-95 civic??
    2009 Lexus ES350
    Titties!!!
    parts added bump. more parts to come when i get more time!!!
    Titties!!!
    ttt
    Titties!!!
    ecu sold bump
    Titties!!!
    someone come buy my shit!!!!
    Titties!!!
    seats pending sale bump!!
    Titties!!!
    ttt
    Žanj-♠ ranj's Avatar
    Quote Originally Posted by preferredduck
    ur seats are doing 69 lol
    free bump
    Titties!!!
    Quote Originally Posted by ranj
    free bump
    yes they are. +1 for a good laugh. it takes up less space that way
