Thread: Oldsmobile Cutlass
    Default Oldsmobile Cutlass
    1970 Cutlass w/ 350 Rocket. 400 Turbo Transmission. New upper and lower control arms, tie rods and bushings. has been converted from drum to disc brakes on front, from points to HEI ignition. two-barrell carb that has been rebuilt. corvette rallies, new kelly springfeild tires. doesnt burn any fuel or leak any fluids. maintain regular. original interior needs repair work - no cracks on dash. needs paint. mechanically very sound car.very straight body- no dents or dings. original glass. perfect for restoration or for parts car for a two door model.
    can anyone tell me what the 350 rocket and the 400 turbo transmission is on these and how much power its probably pushing out? Its from a good looking cutlass and its only 3,300
    Who gives a fuck? Later, QD.
    Umm.. I give a fuck because I want to know what I'm potentially buying.
    Banned onebadbird96's Avatar
    in your mom
    Quote Originally Posted by obear
    so your saying it doesnt run?
    Your post made no goddamn sense. Why not try again and ask proper questions and see where you get. Later, QD.
    in your mom
    OK HOW ABOUT IF IT DONT BURN ANY FUEL ,HOW DOES IT RUN?
    How about you dickheads get some common sense and realize I didn't write the description, I simply asked what the 350rocket and 400 turbo transmission is. If you don't know then I don't care to see your responses.
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    thread failure.. this is how you do it..
    The one and only Buddha buddha@TeamFX's Avatar
    Gainesville, Ga. USA
    $3300 for a rolling chassis a-body is cheap...if it runs its a steal...check for rust...check the floor and trunk pans...check around the bottom of the rear window reveal molding as well...if its a 2-barrell I would say its probably rated somewhere around 250hp...I work at Year One...so if you need any fine details call 1-800-YEAR-ONE. and ask for Chris at the counter...they'll get me and I figure out what you need and go up to the tech library and look everything up...Good luck with the car man! I have a 70 Chevelle myself I'm about to bust off this weekend!...Let me know!
    Year One R&D/New Product
    Budget Boy's Performance EST. 2005
    "We're bustin ours, to kick yours"
