Results 1 to 3 of 3
Thread: fuse diagram
    paint booth
    Default fuse diagram
    i need the door and fuse diagram fo a 96 civic ex. lmk
    random guy's pops!
    random guy's moms cornhole!
    1 — — 10-13 Not used
    2 — — 10-13 Not used
    3 (RR WIPER 10 10-2 Rear wiper, Security system (option)
    RR WASHER) (Vehicles pre-wired for accessory security system)
    4 R H/L HIGH BEAM 10 110-12 Right headlight, DRL control unit (Canada)
    5 L H/L HIGH BEAM 10 110-12 Left headlight, DRL control unit (Canada)
    6 — — 10-13 Security system (option)
    7 (P/W RR-L) 20 120-2 Left rear window motor
    8 (P/W RR-R) 20 120-3 Right rear window motor
    9 (IGN COIL) 15 10-1 Ignition coil (‘98-‘00 models except GX)
    10 (P/W AS) 20 120-1 Front passenger’s window motor
    11 (P/W DR) 20 120 Driver’s window motor
    12 TURN LIGHTS 7.5 10-2 Hazard warning switch
    13 FUEL PUMP 15 10-2 PGM-FI main relay, SRS unit
    (SRS UNIT)
    14 (CRUISE CONTROL) 7.5 10-3 Stereo radio tuner (’96-’98 USA: LX, EX, and HX),
    (KEYLESS) Cruise control main switch, Keyless door lock
    control unit (’99-’00 models with keyless entry)
    15 ALTERNATOR 7.5 10-4 ELD unit, Gauge assembly, TCM (’96-’98 CVT), PGM-FI
    SP SENSOR
    16 RR DEF RELAY 7.5 10-8 Rear window defogger (’96-’98 models), ABS control unit,
    Power mirror switch (’99-’00 models except GX)
    17 HEATER A/C 7.5 10-9 Power mirrors (’96-’98 models and all GX models),
    RELAY Air delivery, Blower controls, A/C compressor
    controls, Fans
    18 (RUNNING LIGHT 7.5 10-8 DRL control unit (Canada)
    RELAY)
    19 BACK-UP LIGHTS 7.5 10-3 Back-up lights
    20 (RUNNING LIGHT) 7.5 10-12 DRL control unit (Canada)
    21 R H/L LOW BEAM 10 110-12 Right headlight
    22 L H/L LOW BEAM 10 110-12 Left headlight
    23 (SRS) 10 10-3 SRS unit
    24 (P/W RELAY) 7.5 10-6 Power window relay, Moonroof
    (S/R RELAY)
    25 METER 7.5 10-6 Integrated control unit, Interlock system,
    Gauge assembly
    26 FR WIPER 20 10-7 Front wiper/washer
    FR WASHER
    27 CIGARETTE 10 10-7 Accessory power socket
    LIGHTER
    ACC SOCKET
    28 RADIO CLOCK 10 (*15) 10-7 Stereo radio tuner (’96-’98 models), Audio unit (’99-’00
    model)
    29 — — — Not used
    30 INSTRUMENT 7.5 114 Dash & console lights
    LIGHTS
    31 STARTER SIGNAL 7.5 21, 21-1, PGM-FI main relay, PCM/ECM, Integrated control unit
    or 21-2
    32 LICENSE LIGHTS 7.5 100-1 Parking lights, License plate lights, Tail lights
    TAIL LIGHTS
    33 (INTERLOCK UNIT) 7.5 10-12 Interlock system
    dnwp
    paint booth
    are they #ed like that.
