Thread: tdc sensor ?????????????????????
    you dont need to know
    Question tdc sensor ?????????????????????
    i have a 92 eg hatch with a 95 b20, every now and then when it is cold out or when i start my car and go in to second gear above 4k rpms it dies down and wont go over 3,500 rpms . i can cut off the key and turn it back on and it is fine. now it dose it sometime when its warm. ? dose this have any thing to do with the tdc sensor. and how do i fix that , is it something to do with the dizzy . any info would help.
    Belview Insane Asylum
    A what?
    tdc ( top dead center sensor)
    Quote Originally Posted by hondachick22
    Never heard of one. But what do I know, I've only been working on Hondas since 1996. I'm not saying it doesn't exist, but I have never seen one so the chances of one going bad are slim if it does exist I would think.
    Cam or crank position sensor maybe?
    i think she's asking about crank position or cylinder position sensor. usually if there is an issue with either it'll give you a cel.
    are you getting any cel? that's usually the first thing to check. if it happens again and you get a cel, but when you restart it the cel goes away try and either check it before shutting it off or stall it out so and don't turn it off so you don't lose the code. the code will direct you.
    i think it in the dizzy or i have the worng dizzy , not surre
    That's what I was thinking.
    replace distributor!
    dizzy is almost new and it is a tdc sensor i look it up. but i dont know what it is. num 8 code from the ecu
