Results 1 to 18 of 18
Thread: FS: Pioneer 2-Channel Amplifier
    Default FS: Pioneer 2-Channel Amplifier
    Brand NEW just opened the box and took the amp out for a pic. Comes with box, wires, manual, ect...since it's NIB...Has not been used and will include a receipt if needed.
    $95
    A really good amp doesn't just provide power. It also offers options for customizing the sound in your vehicle. The 2-channel GM-5200T provides a selectable 50Hz bass boost and a built-in crossover for fine-tuning your tunes. Plus, it comes with speaker level inputs for easy connection to an OEM headunit.
    Selectable 50Hz Bass Boost
    Bass boost gives you more control over how your music sounds. It lets you set the optimal bass level for each speaker/sub connected to the GM-5200T, so the tone controls from your headunit can do what they do best. And because this is selectable bass boost, you can set the level at 0dB, 6dB, or 12dB, whichever sounds best to you.
    Built-In Crossover (80Hz Low-Pass Filter)
    Built into the GM-5200T is a very smart crossover network. It works like a gateway, routing the big bass signals (80Hz or lower, at -12dB/octave) to the speaker that handles them best, filtering out higher-frequency signals to that speaker. This optimizes your system's efficiency and delivers the best possible sound quality.
    Speaker Level Inputs
    What, you DON'T own a Pioneer headunit? Well, we won't hold it against you. In fact we'll even help you build onto your system. The GM-5200T's speaker level inputs allow you to connect your OEM unit (or any unit that doesn't have the typical RCA-type inputs) without having to buy add-on adapters. SO, the install goes faster, you save money, and you've got a Pioneer amp in your vehicle.
    CEA2006 Specifications:
    • 125 Watts x 2, at 4 ohms <= 1% THD+N
    • 380 Watts x 1, at 4 ohms BRIDGE <= 1% THD+N
    • 75 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
    Key Features
    * Bridgeable
    * Screw-Type Speaker Terminals
    * PWM Regulated MOSFET Power Supply
    * Balanced Isolator Input Circuit
    * RCA Inputs
    * Speaker Level Input
    * Input Level Control Hi-Volt (400mV ~ 6.5v)
    * Built-in Crossover - Selectable LPF
    * Crossover Frequency Range 80Hz, -12dB/Oct.
    * Bass Level Control 50Hz, 0/6/9/12dB
    * Warranty 1 Year
    Specifications
    * Peak Music Power 760 Watts
    * Load Impedance Capability 2~8 Ohm (Stereo)
    * Continuous Power (4 ohm) 125W x 2
    * Continuous Power (2 ohm) 190W x 2
    * Continuous Power Bridged (4 ohm) 380W x 1
    * Frequency Response 10Hz ~ 50 kHz
    * Total Harmonic Distortion 0.015%
    * Signal-to-Noise Ratio >95dB
    * Dimensions 11-13/16" x 2-3/8" x 13-1/4"
    your moms house
    damn seems like a good deal. whered you get it?
    FUCK B&D COMMUNICATIONS!
    Thanks SteveO!
    Hopefully someone will get this amp sometime this week. I have someone holding an amp for me which is rated at more power since I decided to upgrade speakers lol.
    $70 call 404 625 4235
    in wall mart same amp $110 NEW
    PM IF INTERESTED
    Default I GET IT!!!
    PM IF INTERESTED
    I'd have to skip on that offer.
    The amp is still new. I just got it this week and haven't even hooked it up to anything. Just decided to go in a different direction.
    Thanks
    Bizzump
    Bump before sleeping!
    Bump to the top!
    Bump up...had a few calls but nothin solid...
    So $90 if you're local
    B u m pin UP!
    Bump it up again
    Bump up once again
    Bumppitty uppity
    Goinnn up!
    Come n' get it! Priicee drop to $85
    Goin up again
    Up to the top!
