Results 1 to 4 of 4
Thread: FS- 35mm Canon Rebel K2
    not a dude dizzle's Avatar
    Lawrenceville/Loganville
    Default FS- 35mm Canon Rebel K2
    its old skool film but less than a year old.
    asking 125 obo
    includes bag, camera, the strap for the camera, and booklet that tells u all about it...
    all the specs:
    Product Features-
    -35mm SLR camera with date/time imprint function
    -7-point autofocus
    -35-zone metering system
    -Compatible with more than 50 Canon EF lenses, EX-series Speedlites, and many other EOS system accessories
    -Powered by 2 CR2 lithium batteries housed inside the camera grip
    Technical Details-
    Camera Type: 35mm focal plane shutter SLR (Single-Lens Reflex) autofocus / autoexposure camera with built-in motor drive and retractable flash
    Lens Mount: Canon EF mount (electronic signal transfer system)
    Usable Lenses: Canon EF lenses
    Viewfinder: SLR-type, eye-level roof prism mirror gives 90 percent vertical and horizontal coverage of actual picture area and 0.70x magnification with 50mm lens at infinity
    Mirror: Quick-return half mirror
    Standard Diopter: Adjusted to -1. (18.5mm eye relief)
    Focusing Screen: Fixed, full-surface new laser-matte screen marked with focusing points
    Viewfinder Information: Numbers and symbols displayed by LCD at bottom of viewing area. (Yellow-Green)
    Viewfinder Display: 1. Shutter speed (If unsuitable blinks at 2 Hz as a warning.), 2. Aperture (If unsuitable blinks at 2 Hz as a warning.), 3. :Indicates AE lock or FE lock (Partial metering at center.), 4. :Exposure level scale with dot indicators in 1/2-stop increments. (±2 stops), 5. :Lights when flash is ready; blinks at 2 Hz if flash range is ineffective during FE lock, 6. :Lights during high-speed sync. (FP flash), 7. :In-focus indicator. (Blinks at 2 Hz if focus cannot be achieved.), 8. :AF Point selection and active AF point are indicated.
    Shutter: Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control. (Curtain speed: 6.3ms / 24mm)
    Shutter Speeds: 30 to 1/2000 sec., Bulb; X-sync at 1/90 sec. Can be set in 1/2-stop increments
    AF Control System: TTL-SIR (Secondary Image Registration) CMOS sensor
    Focusing Point Selection: The focusing point can be selected by camera (Automatic) or by user (Manual)
    Focus Modes: 1. Autofocus (One of the following three AF modes is set automatically depending on the picture-taking mode. The shutter does not release until focus is achieved): a. One-Shot AF: Autofocus locks when focusing is achieved, b. Predictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts, c. AI Focus AF for automatic switching between One-Shot AF and predictive AF for moving subjects. 2. Manual Focus Setting the lens' focus mode switch to MF enables manual focusing with the focusing ring.
    Focus Operation: Autofocus is activated by pressing the shutter button halfway
    AF Working Range: EV1-18 (at ISO100)
    AF-assist Beam: Automatically emitted when necessary and aimed at the area covered by the active focus point.
    Light Metering: 1. TTL full-aperture metering using 35-zone SPC (Silicon Photocell). Three metering patterns available: a. 35-zone Evaluative Metering, b. Central partial metering which covers approximately 9.5 percent of finder area, c. Center weighted average metering (Set automatically in M mode.). 2. E-TTL: 7-point, 35-zone pre-flash metering using Speedlite 550EX, 420EX, or 220EX. 3. A-TTL, TTL Flash Metering: off-the-film, 3-zone A-TTL autoflash linked to focusing points, 3-zone TTL autoflash metering.
    Metering Range: EV 1-20 (with 50mm f/1.4 lens at ISO 100)
    Exposure Modes: 1. Intelligent program AE with variable shift, 2. Shutter speed-priority AE, 3. Aperture-priority AE, 4. Auto DEP, 5. Full Auto (Intelligent program AE, unshiftable), 6. Programmed Image Control Modes: Portrait, Landscape, Close-up, Sports, Night Portrait and Flash Off, 7. E-TTL program flash AE, 8. A-TTL program flash AE, 9. TTL program flash AE, 10. Metered Manual
    Exposure Compensation: 1. Auto Exposure Bracketing (AEB) up to ±2EV in 1/2 steps. 2. Manual exposure compensation up to ±2 EV in 1/2 steps. 3. Unavailable in the Full Auto and Programmed modes.
    Multiple Exposure: Up to 9 exposures can be preset. Automatically clears upon completion. Cancelable midway.
    Film Speed Setting: ISO 25-5000 automatically set in 1/3 step increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 step increments.
    Film Loading: Automatic prewind system. After film positioning and back cover closure, the film automatically winds to the 1st frame.
    Film Transport: Single-frame advance or continuous advance set automatically according to the picture-taking mode.
    Film Wind: One of two modes can be set: Single Frame and Continuous. (In Continuous Mode, with AF locked, approximately 1.5 fps.)
    Film Rewind: Automatically rewinds at the end of roll. Midroll rewinding possible.
    Quiet Film Transport: Film winding sound level: Approximately 60dB
    Film Transport Confirmation: By up/down counting of frame counter in LCD panel.
    Flash Type: Built-in, retractable TTL autoflash head in the pentaprism. Auto pop-up and serial-controlled.
    Guide Number: 39 ft / 12m (ISO 100)
    Flash Coverage Angle: Covers the angle of view of 28mm lens.
    Recycling Time: Approximately 2 seconds. The icon lights in viewfinder when ready
    Flash Duration/Color: 1ms or less / equivalent to daylight
    Shooting Distance Range(ISO : Wide: 28mm Negative Film, Wide: 28mm Reversal Film, Tele: 80mm Negative Film, Tele: 80mm Reversal Film): 100 : 3.0 feet - 4.6 feet, 3.0 feet - 9.8 feet, 3.0 feet - 9.8 feet, 3.0 feet - 6.9 feet; 200 : 3.0 feet - 19.7 feet, 3.0 feet - 13.8 feet, 3.0 feet - 14.1 feet, 3.0 feet - 9.8 feet; 400 : 3.0 feet - 27.9 feet, 3.9 feet - 19.7 feet, 3.0 feet - 19.7 feet, 3.0 feet - 14.1 feet
    Red-Eye Reduction: Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved.
    Battery: Two CR2 lithium batteries housed inside the camera grip
    Battery Check: Battery level is displayed by the battery level indicator on the LCD panel. Battery level is indicated in one of four levels.
    Shooting Capacity(Ambient Temperature : Flash Not Used, 50 percent With Flash, 100 percent Flash Use): Normal Temperature(68 degrees F/20 degrees C): 67, 30, 22; Low Temperature(4 degrees F/-20 degrees C): 44, 20, 15
    Shooting Modes: Full Auto, Portrait, Landscape, Close-up, Sports, Night Scene, Flash Off, Intelligent Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, Manual Exposure, Automatic Depth-of-Field AE
    Continuous Shooting: Approx. 1.5 images/sec
    Date/Time Imprint: (EOS Rebel K2 Date only) Day/Month/Year, Month/Day/Year, Year/Month/Date, Date/Hour/Minute
    Dimensions: 5.1 (W) x 3.5 (H) x 2.5 (D) inches / 130 (W) x 88 (H) x 64 (D) mm
    Weight: 12.9 ounces / 365g without batteries
    anyways this is a good camera if you like to use film. i dont need it anymore since i just got a new one.
    In a mansion
    Not a bad camera my mom has one, i opted for the d slr xti.
