Thread: lots of pressure build-up
    F.T.W.K.T.A.
    Dalton
    Unhappy lots of pressure build-up
    hey guys if you remember i had a problem with overheating with a new d15b, i thought i had it solved but now there is exessive pressure build-up and it is starting to overheat fast.....and everytime i try to bleed the cooling system there is an endless amount of air being released and the only way i can get the oressure to go away is by shutting off the car and bleeding it for about 2-3 minutes..... what chould this possibly be and how can i fix it....and thanx i advance guy and gals
    94 civic Dx 4dr - N/A Ls/Vtec
    94 Del Sol Si - Project O'SH is GO!!!
    91 Accord Lx - Totaled
    Oct 2003
    blown gasket or crack in cylinder head...once it warms up the pressure from combustion chamber escapes into the cooling system
    your moms house
    Quote Originally Posted by Annihilation
    thats what i was thinking....
    have you pressure tested or compression tested the motor?
    FUCK B&D COMMUNICATIONS!
    F.T.W.K.T.A.
    Dalton
    i pressure tested it and it was 190 all the way across but i haven't since it's been acting funny
    or cracked sleeve.
    did you do a leak down or just a compression test?
    F.T.W.K.T.A.
    Dalton
    just compression test, the motor only has about 35k on it the guy i bought it from bought it from jarco for 1500 i bought it from him for 275 with a 4.5lb lightened fidanza flywheel... i talked to the guy today and he said iyt was fine when he pulled it but he'd help me with whatever needed to be done..and what do i need to do a leakdown test? so if the head is cracked i already have another same with the block......
