Results 1 to 10 of 10
Thread: FS: Built 91 Talon AWD
    Lurker Brick's Avatar
    Canton, GA
    Default FS: Built 91 Talon AWD
    6 bolt block bored .20 over w/ around 30k assembled by AMS
    2g pistons
    1g big rods
    clevite 77 bearings
    ARP head studs
    factory head gasket
    head port and polish done at time of rebuild
    fresh water pump, front cover, timing belt, oil pump, and harmonic balancer
    removed balance shafts
    metal gaskets, new pcv valve, new brake booster
    all silicon vacuum hoses
    dejon tool 2g-1g intake pipe with recirc
    2g mas air flow sensor
    cosmo filter & 2g adapter plate
    1g bov
    stock 60mm intake manifold
    AMS slimline fan
    ported 2g exhaust manifold
    PTE 50 Trim turbo, .60 A/R, stage III wheel
    HKS External Wastegate
    JRP 32x7x3 FMIC with short route piping
    ported EVO III o2 manifold
    Full 3" turbo-back exhaust with Vibrant muffler
    Joe P Manual boost controller
    walbro 255 pump
    new fuel filter end of '04
    Charged Air Systems adj. Fuel Pressure Regulator
    B&M Fuel Pressure Gauge
    PTE 680cc ball/disk injectors
    JDM transmission w/ TRE rebuild - few thousand miles on it
    -Upgraded 1/2 double synchro set
    -Steel EVO III shift forks
    -Steel shift rails
    -Upgraded 3/4 gearset
    Fidanza Short Shifter
    Raxles front Axles
    S-AFC 1 With Blue Wire Mod
    ApexI Turbo Timer
    Installed Datalogger cable
    Autometer Boost guage
    SS clutch line
    ACT 2100 clutch with replaced TOB
    resurfaced flywheel
    Progress springs 1.25" drop in front 1.5" in back
    KYB GR-2's
    GVR-4 dual piston calipers
    3000GT SL front rotors
    Mitsubishi pads
    NX-7 Gunmetal rims with polished lip
    new Pioneer CD/XM head unit
    Diamond CM3 6.5" front speakers
    Polk/Momo 6x9 rear speakers
    Viper Alarm
    I bought it with all of that done minus the Polk speakers, Fidanza Short Shifter and Viper alarm, which I had done. Previous owner said all work was done within about 30k miles, so everything mentioned is pretty much new. I also put BG Syncroshift II in the tranny and Amsoil 75W-90 in the rear differential. Only had it since May 6. I just need the money for some other things.
    http://img70.echo.cx/img70/320/talonpics0018ij.jpg
    http://img70.echo.cx/img70/9209/talonpics0022ni.jpg
    http://img70.echo.cx/img70/3292/talonpics0036xm.jpg
    http://img70.echo.cx/img70/8648/talonpics0046zt.jpg
    http://img70.echo.cx/img70/7460/talonpics0059hh.jpg
    http://img70.echo.cx/img70/9974/talonpics0067ej.jpg
    http://img70.echo.cx/img70/882/talonpics0097lw.jpg
    http://img70.echo.cx/img70/7328/talonpics0109fj.jpg
    Car is located in Canton, GA.
    Asking $6,500 or a reasonable offer.
    Contact [email protected] to further discuss.
    Canton, GA
    pics fixed.
    Canton, GA
    does it pass emissions, clean title?
    Canton, GA
    clean title, no catalytic converter
    RUTSPEED / Boobies ! RutRoe's Avatar
    Peachtree City Area
    Wow.. that car looks like it was relaly well built. Good luck with the sale, wish I had the cash for it.
    BooB CreW What ?
    One of IA's Awesome Mod's
    NASCAR on SPEED's Fun Guy
    HOST, Top Gear USA on History Channel starting late this Nov./Dec.
    Canton, GA
    Rotary Man redlinenprelude's Avatar
    lilburn/snellville
    i have seen that car on buford hw at a car wash? so nice we stoped and got out to look.. bump
    Canton, GA
