Results 1 to 2 of 2
Thread: Dual 2 12"'s Sub Enclosed + Amp
    On The Grind.. Djlin's Avatar
    Default Dual 2 12"'s Sub Enclosed + Amp
    Well this wasn't getting much attention in the car parts section so i am going to try it over here..
    i have a Dual XOBP12D 12" Dual Bandpass Sub System with an Dual 580W amp for 200$ obo
    Great system guaranteed to work and also comes with an 2 year best buy replacement plan anytime these blow or go they will replace it no questions asked!
    Bring the noise with the heavy-duty Dual XNBP12D enclosed subwoofer, which features a carpeted enclosure, plexi subwoofer viewing window, and unique blue illumination. The patent-pending illumiNITE technology constantly illuminates the subwoofer with blue LED lights when it is in use. This box makes a simple and easy add-on for existing systems with no crossovers needed. It provides 600 watts of RMS power and 1100 watts of peak power. Dual's enclosure utilizes a specialized tuned-port computer-aided design to increase the output efficiency. The nailed and glued construction with added bracing is used to eliminate enclosure movement caused by high sound pressure levels. Other features include dual 12-inch Low-Q optimized drivers for loud, accurate bass, four-port dual chamber design, and a mirrored/diamond-plated chamber.
    The XOBP12D is a looker, but its beauty is more than skin deep. The ported, dual 12-inch bandpass system is capable of handling 600 watts of continuous bass energy, and able to absorb a whopping 1,100 watts of peak power. Low-Q optimization means less unwanted acoustic resonance, and integration into any mobile system is simplified by the systems built-in crossover design.
