Results 1 to 17 of 17
Thread: Sticky this bitch: Shallow staging and launching
    2.3 Evo 8
    Guest
    Default Shallow staging and launching
    This deserves reps you slooooots!
    I PMed everybody that asked, but here it is in a nutshell.
    I was cutting consistent 1.7 60' times at the track with this technique while using regular street tires. With drag radials or slicks, 1.5-1.6's can be achieved with the same technique. Pressure in the tires can be adjusted accordingly to help with more or less grip depending on track conditions.
    This technique will also be much easier on the drivetrain if you do it this way so you don't shock the drivetrain. You can take this technique and change it to best suit your needs.
    "Shallow" Staging and launching at the track:
    1. Pull up and get the first yellow light to come up. This is just a courtesy light to let you know you are close to the second beam. I believe 9 inches away.
    2. While you are stopped for the first yellow, pull up your emergency brake to keep the car from rolling forward.
    3. Push in the clutch, put the car in 1st gear, then let out the clutch until it just begins to grab slightly while releasing the e-brake, this will allow the car to "slowly" pull forward to get the second staging yellow to light up.
    When I say "slowly", I mean VERY slow. You want to make the 2nd yellow light to barely come on. If you can get the 2nd yellow to actually flicker, you are considered to be "shallow staging".
    Shallow staging allows you to get a rolling start before breaking the last beam.
    4.Once the 2nd yellow comes on or begins to flicker, pull the e-brake up all the way and SLOWLY let the clutch out until it "barely" begins to grab. When it just starts to grab, don't move the pedal anymore. Leave it at that point where it is barely engaging. It is very important that you don't let it go in or out any further.
    5. The tree will then give you 3 yellows before it turns green. Give the car 100% throttle for the 1st countdown yellow.
    6. When the 3rd yellow is about to flash, slowly begin to release the clutch while also releasing the e-brake. You are still 100% throttle and rolling forward.
    You will only slip the clutch for about a split second and the car should roll forward maybe 1 foot or less before you completely dump the clutch. It is considered a quick slip and dump.
    This part is where practice makes perfect. Timing is everything during this step. Once you get the timing down and can repeat it consistantly, you'll see results in your overall times.
    That is how I launch.
    I know it sounds strange, but by shallow staging and getting a rolling start, you don't "SHOCK" the drivetrain. You will be less likely to break something by getting the car rolling.
    If you have a 2-step control on your car, you can make adjustments to what rpm to come off the line. Track conditions will be different from one track to another. I can normally leave my 2-step the same and just adjust the tire pressure, but for some tracks the car just reacts different and an adjustment to the 2-step is needed.
    For anybody just free revving the motor to lauch, you might go 100% full throttle on the second countdown yellow instead of the first. You will need to figure out the best time for you to go 100% full throttle. It could be the 1st yellow, 2nd yellow, or between the 1st and 2nd yellow. In some cars you can also use/set the stock rev limiter and use that to your advantage where a 2-step isn't available.
    AWD cars:
    Everything you heard about destroying a tranny or transfer case in an AWD is from dumping the clutch from a stand still or in an extremely high horsepower AWD. Yes it can be done, but it takes a toll and it can destroy parts at any given time. Revving the car to whatever rpm and dumping it from a stand still just shocks the shit out of the drivetrain and is too risky.
    A 2.0 second 60' feels decent, but a 1.5-1.7 feels completely different.
    Maybe this video will help with shallow staging part.
    http://media.putfile.com/Drag-School
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    reps for you sir
    2006 Evo IX - Bolt ons
    your moms house
    nicely done
    FUCK B&D COMMUNICATIONS!
    banned from heaven..
    rep'd
    <-- Ohhh! (my boy) FAHHQUE700's Avatar
    Down in A-Town
    :boobies:this has been around for a long time..... The easiest way... pre-stage... tranny brake, load tranny, hold limiter, last yeller, hit the red button.:boobies:
    MAY CAUSE CANCER Psycho's Avatar
    Standing Right Behind You
    My tranny would instantly destroy its self, if I did that
    You must spread some Reputation around before giving it to 2.3 Evo 8 again.
    Smyrna
    Good information, rep'd ya.
    98 EJ8 - Stolen ( Thieves)
    Certified Gearhead lemansz's Avatar
    my evo made 338 awhp and went 12.0 @ 114
    at another track i went a 7.60 in the 1/8 @ 92
    is that good?
    i went a 1.65 60 foot on my advans
    2.3 Evo 8
    Guest
    Yes, thats very good.
    Quote Originally Posted by 2.3 Evo 8
    sweet!
    Roswell, GA / Georgia Tech
    nice info, reps
    Smackyaselfville
    nice info
    Project Vox has begun
    Turbobricks.com member
    GeckoSquad
    Banned Stopsnitchin's Avatar
    thanks. +1
    keeps it REAL!! koffebean00's Avatar
    Bump for some newbs that need to learn how to launch.
    Quote Originally Posted by koffebean00
    x2
    ttttn
