Quick Story..
Replaced rotors and pads on front end. Bleed the brakes. Everything great.
For the first month since replacing everything was fine.
NOW -
Left side squells like crazy. When driving slow you can hear a pattern grind going with the speed. Also when driving its a pattern sound that goes with how fast you are traveling. When you pull the brakes its grinding hard only on the left side.. Sounds like the rotor is warped? To me its a hard grind when stopping..almost sounds like metal, but I checked the pads and there is still padding on them. Not 100% sure.
Any suggestions would be appreciated so when I hit them brakes this week, I know what to replace. Otherwise I am buying a new rotor and making sure the brake pads havent been killed yet.
