Results 1 to 10 of 10
Thread: Treadwear problems
    New Adventure Ahead
    Snellville
    Default Treadwear problems
    I have a problem with tread wear on my truck. I have replaced tires, had an alignment, balnced etc. The outsides of the front tires keep wearing down before the rest of the tire. I wanted to know if it is a suspension problem or what?
    ~LilMonty
    Quote Originally Posted by CH@Dbee
    neons are sloooow.
    except for the black ones
    Certified Gearhead bluuuurr's Avatar
    Oct 2003
    Monterey, CA
    what year is your truck? have you checked your bushings?
    I had a civic that kept eating up tires on one side. I had it aligned and all.. it ended up being a rotted control arm bushing that I replaced for like 12 dollars :P
    Ohio asshole.
    Sounds like a ford lol. Could be the suspension is sitting to high with out the proper parts to counter for the tire wear.
    If it is a ford, You can get brackets to drop the truck mounted side of the I beam. Otherwise the only way to fix is to bring your suspension down, or have the I beams bent.
    **Note- I Dont KNOW that this is a ford. But It does sound like a ford symptom. My dads GMC was also doing the same thing. Lower control arm was actually bent sucking the bottom of the tire in.
    New Adventure Ahead
    Snellville
    It is actually a Chevrolet. 2001, Silverado 2500. I was going to post pictures but I can't find the camera.
    Thanks for the info.
    neons are sloooow.
    rotate your tires every oil change as well.
    New Adventure Ahead
    Snellville
    Will do. Thanks
    ~LilMonty
    neons are sloooow.
    One thing i forgot, have you checked your air pressure? I'd run about 36-38psi in a truck. Even with my brand new truck, good alignment etc i get some uneven wear. I crossrotate my tires every oil change to help balance it out and get even wear. Im a mechanic btw so i align any time its in question.
    New Adventure Ahead
    Snellville
    OK, cool. Thanks for the tips.
    neons are sloooow.
    Hmmmm?
    Ohio asshole.
    Quote Originally Posted by GSRteg
    Hmmmm?
    Point in that??? Idiot.
