Results 1 to 24 of 24
Thread: FS: Kicker Mono Amp
    Certified Gearhead GET8UP's Avatar
    Conyers
    Default FS: Kicker Mono Amp
    I'm selling a Kicker SX1250.1 amp. It is in good condition. Here are the specs.
    Product Description:
    MODEL: SX1250.1
    625 watts RMS x 1 at 2 ohms
    1250 watts RMS x 1 at 1 ohm
    1-ohm stable
    amp operates at 4 ohms (producing 312 watts), but Kicker recommends a 2- or 1-ohm load for maximum performance
    requires 2-gauge power and ground leads -- wiring and hardware not included with amplifier
    keypad menu control
    variable low-pass crossover (30-200 Hz) with adjustable slope (choose from 6, 12, 18, 24, 30, 36, 42, and 48 dB/octave)
    variable subsonic filter (10-60 Hz) with adjustable slope (choose from 6, 12, 18, and 24 dB/octave)
    Digital KickEQ single band parametric equalizer with variable center frequency and variable Q
    Wired Bass Remote included
    Kompressor expansion/compression circuitry with four settings: Off, Contour, Attack, and Redline
    4 memory banks store intricate EQ cut/boost, low-pass crossover, phase, bass boost, sub-sonic filter, and compression settings
    Sick Bay technology for real-time diagnostics and troubleshooting (includes pink noise generator)
    preamp outputs
    UltraMatch gain control for optimal input level matching
    amp strapping circuit lets you connect a second SX1250.1 amp for double the power output
    cooling fan
    22-1/2"W x 2-1/2"H x 10"D (17-1/2"W without endcaps)
    Amplifier Specifications:
    Number of Channels 1
    RMS Power (4 ohms) N/A
    RMS Power (2 ohms) 625 watts x 1 chan.
    RMS Power (1 ohm) 1250 watts x 1 chan.
    Bridged RMS Power Not Bridgeable
    Peak Power Output Not Specified
    Min. Impedance Unbridged 1 ohm
    Min. Impedance Bridged Not Bridgeable
    THD @ Rated RMS Power 1.5%
    Speaker Level Inputs No
    Amp Preamp Outputs 1 Pair
    Built-in Crossover Yes - HP / LP
    High-Pass Crossover 10 - 60 Hz
    Low-Pass Crossover 30 - 200 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio 98 dB
    Channel Separation N/A
    Bass Boost -18 -- +18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 150A
    Price: $250 OBO (it sells on ebay for $400-$500)
    Attached Thumbnails Attached Thumbnails -img_1312-jpg
    Conyers
    Conyers
    Conyers
    Conyers
    Conyers
    Geogia
    $250 ill take it out of your hands right away
    Conyers
    Conyers
    Conyers
    whats the lowest you'll take?
    Conyers
    Conyers
    Conyers
    bump for new price
    Chargin
    The Ville'
    Conyers
    what do you mean ????
    Conyers
    Conyers
    In a mansion
    Bump for a semi sick amp..
    Conyers
    bump for new price
    Conyers
    Twan Jdm94Coupe's Avatar
    Fairburn
    sold??
    Conyers
    i still have it
