Results 1 to 25 of 25
Thread: Tire Numbers
    Here and there Hulud's Avatar
    Omnipresent
    Default Tire Numbers
    what do they mean?
    215/45/17?
    i know the 17 is the inside diameter for the rim size but what are the other two?
    Val for President
    Formerly Spyder Man
    Buford, Ga
    215= 215 MM or 8.41 inches
    45 is a series aka a percentage of the width displayed in height from the rim to the tread patch(aka sidewall) or in this case 96.75mm or 3.78 inches.
    to get the total over all height you can do rim height+ (2Xsidewall)= total height
    again in this case 17+(2x3.78)= 24.56 inches in over all height, ideally you want to maintain as close to a factory circumference to not throw off you handeling and speedo charecteristics.
    :boobies:
    Omnipresent
    sweet man thanks
    so what i would want would be something close to the 24.56 overall?
    i mean hopefully my stock is close to that number
    Val for President
    Formerly Spyder Man
    Buford, Ga
    all depends , do you know what size your factory tires are/were?
    :boobies:
    Omnipresent
    i will just a sec lemme check
    Val for President
    Omnipresent
    Val for President
    Formerly Spyder Man
    Buford, Ga
    btw as long as you are willing to recalibrate your speedo it isnt a huge deal to run slightly off sized wheels/tires.
    :boobies:
    Omnipresent
    damn. will it make me slower or faster?
    Val for President
    Formerly Spyder Man
    Buford, Ga
    205/55/15
    205/25.5454=
    8.02 tread width.
    x.55 (series)=
    4.41 sidewall
    15+(4.41x2)=23.82
    that is a pretty serious difference..
    Last edited by Spyder Man; 06-24-2005 at 03:39 PM. Reason: cause i had a x where there should have been a /
    :boobies:
    Jan 2005
    Columbus, Ga
    love my 215/35/18
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Formerly Spyder Man
    Buford, Ga
    your speedo will be slower.
    if you are going 60 it will likely read about 52 or so with the new wheels/tires.
    :boobies:
    Omnipresent
    so i would get a speeding ticket i guess
    Val for President
    Formerly Spyder Man
    Buford, Ga
    you can get it recalibrate as i said or go with properly sized tires.. your call
    :boobies:
    Omnipresent
    yea about how much does that run to recal?
    Val for President
    Omnipresent
    so the first number is the width of the tire?
    Val for President
    Formerly Spyder Man
    Buford, Ga
    no idea , its different for all cars.
    but to give you an idea of what kind of tires to look for next time..
    origional-23.82
    205/40/17-23.41
    205/45/17-24.21
    215/40/17-23.72
    215/45/17-24.57
    225/35/17-23.16
    225/40/17-24.04
    235/30/17-22.51
    235/35/17-23.43
    personally 225/35/17's sound good but obviously 215/40/17's are the closest.
    :boobies:
    Formerly Spyder Man
    Buford, Ga
    yes it is the width in millimeters.there are approximately 25.5454 millimeters per inch , i did a conversion so you could better understand it.
    :boobies:
    Omnipresent
    so any of those sizes you gave me will fit the rims i have?
    Val for President
    Formerly Spyder Man
    Buford, Ga
    dunno, i would assume you have atelast 17x7's so technically they will all fit. it my personal preferenc to have a slightly wider tire then a little slim skinny one. the skinnies generally cost less just so you know..
    :boobies:
    Omnipresent
    ok im gonna check on the rim size brb
    Val for President
    Omnipresent
    yup 17x7
    Val for President
    Omnipresent
    well thanks man for the awesome help!!!!!! +1 for you
    Val for President
    Omnipresent
    oh damn i will give you some soon it wont let me give anymore right now!
    Val for President
    Formerly Spyder Man
    Buford, Ga
    yup 17x7
    then yes anything will fit, the 215 or 225 width will look the best.
    :boobies:
    Omnipresent
    awesome thanks!
    Val for President
