Results 1 to 5 of 5
Thread: XX Maxximus, Anyone seen this before?
    Dacula GA
    Default XX Maxximus, Anyone seen this before?
    10,000 watts? HOLY FUCKEN SHIT!!!
    http://www.onlinecarstereo.com/CarAu...roductID=16720
    Technical Specification
    * RMS Power Range : 2000-10000 Watts
    * Number Of Channels: 1
    * Low Frequency response: 2 Hz
    * High Frequency Response: 70000 Hz
    * Built In Crossovers: Yes
    * Channel Separation: Yes
    Features
    * 10-kilo Watts /1 x 10,000-Watts RMS @ 2-Ohm
    * 2000 watts RMS x 2 channels into 4 Ohms (stereo)
    * 3500 watts RMS x 2 channels into 2 Ohms (stereo)
    * 5000 watts RMS x 2 channels into 1 Ohms (stereo)
    * 7000 watts RMS x 1 channel into 4 Ohms (bridged)
    * 10000 watts RMS x 1 channel into 2 Ohms (bridged)
    * Suggested In-Line Fuse Rating 1100 Amps
    * Frequency Response 2Hz - 70 K Hz (-3dB)
    * Damping >400
    * Signal to Noise Ratio >98 dB
    * THD + Noise 0.1%
    * Variable Input Level 0.2V - 9V (RCA/Unbalanced)
    * Variable Input Level 0.4V - 18V (Mini DIN Balanced)
    * Dimensions 11.20 W X 5.50" H X 28" L (Endcaps + 5.32")
    * 2/1-Ohm Speaker Impedance Capable with Quad Turbo Power Supply Torroids in a PWM MOSFET Power Supply Design.
    * Rock Stable Ultra-Fi™ MOSFET Outputs
    * Excessive Cone Excursions Controlled by Subsonic Filter
    * Wide Voltage Range Variable
    * Input Level Controls
    * Adjustable Crossovers For Better Subwoofer Control
    * High Damping Factor For Precise Transient Response
    * Phase Shift Correction For Asymmetrical Speaker to Ear Distances
    * Balanced Line Input, for Optional MMBLD-1 Balanced Line Driver
    * Highly Efficient Ultra D-Class™ Amplifier Topography
    * Low Impedance Stability
    * Mono-Block Capable for Subwoofer Operation
    * Versa-Cross™ Crossover Adjusts Low-Pass, Subsonic, Phase & Q
    * Blue Illuminated Logo
    * XXR-1 Remote Bass Control Included
    * High-Speed Ultra-Fi™ MOSFET Output Devices
    * RJ45 IN/Out Controls 2-Amps With One Remote Bass Control
    * RCA Line-Outs for Multiple Amplifier Systems
    * Soft Start Prevents Turn-on Thumps
    * Variable - 24dB Subsonic Filter (10Hz to 50Hz)
    * Adjustable Low-Pass (35Hz to 250Hz)
    * Variable Bass Boost (+ 18dB)
    * Bass EQ Variable 30Hz to 60Hz
    * Q-Control (Wide to Narrow Bandwidth)
    * Phase Shift Control Adjusts, 0 to 180
    * Balanced Line Input (Use optional MMBLD-1 Line Driver)
    * Protection System Diagnostics
    * Overload Protection
    * Thermal Over-Temp Protection
    * Speaker Short Circuit Protection
    * Amplifier Endcaps Included
    Dacula GA
    is this really necessary? what would need 10000 watts at 1 ohm?
    the land of race car ya-yas.
    imax theater uses a little more than that. like 12 or 13k.
    that's insane.
    Dacula GA
    Quote Originally Posted by KDM guy
    that's insane.
    this is for a car... how many batteries would be needed to power this?
    i have no idea.
    i'm not an audio guy. all i did in my car was the fiberglass.
