Results 1 to 2 of 2
Thread: FS: ITB SETUP 16v HI-COMP
    OldSkool jdmjohn's Avatar
    Default FS: ITB SETUP 16v HI-COMP SOLD!!! MODS, PLS DELETE, THX
    i just pulled them off my motor.
    this setup will include:
    -technotoytuning 16v smallport itb manifold
    -ae101 20v itb's w/ 20v tps sensor
    -chrome velocity stacks
    -7 barbed vac tank
    -oem mechanical idle control w/ custom plate
    -240cc injectors (compatible w/ your injector plugs)
    -megasquirt and spark code 29v 1 v3.0 board
    -plug and play adaptor harness
    -plug and play adaptor iat sensor/fuel pump jumper wire (plugs up to your existing afm plug
    -plug and play adaptor 20v to 16v tps sensor
    -serial to usb adaptor
    -12ft usb cables
    -cold start injector screw plug
    you can download the program here: http://www.megasquirt.info/MS%20FAQ.htm or i can provide it for you on a cd. ive already loaded the latest code and my personal itb msq. file into the megasquirt. if needed, ill put my msq. file on a cd so you can tune it to your engine specs.
    updated pics:
    i was asking $1100, now $1000 obo.
    i can ship to any 48 states for 25 buck more.
    sold. that was quick.
