Results 1 to 5 of 5
Thread: RSX RADIO REMOVAL...
    y tu mamá tambien!! Dave's Avatar
    Lawrenceville, GA
    Default RSX RADIO REMOVAL...
    WHERE DO I START?? DO I HAVE TO REMOVE THE LOWER PANEL (IN THE DASH) AND UNSCREW THE RADIO COMPARTMENT?? OR IS THIS ONE OF THOSE THAT YOU CAN USE THE FRONT TOOL TO TAKE IT OUT?? I NEED THE SERIAL # OF THE THING SO I CAN GET THE CODE FROM ACURA... MAN I HATE THAT STUFF.
    I talk shit, dont ban me
    LA bitch
    UHM DUDE ITS REAL REALLY EASY
    THE MIDDLE SECTION THAT CONNECTS THE CENTER CONSOLE AND UPPER DASH.. WHERE YOUR CIGARETTE LIGHTER IS.. POP THAT OUT
    THAN THE SCETION WHERE YOUR RADIO IS... PRY THAT OUT TOO.. I TYPICALLY USE A FLAT HEAD SCREW DRIVER AND WEDGE IT AT THE CORNER WHERE THE HAZARD LIGHT SWITCH IS AND THE REST SHOULD POP RIGHT OUT.. SERIOUSLY VERY SIMPLE..
    IF YOU HAVE A TYPE S LIKE I DO AND YOU STILL HAVE THE FACTORY HU IN THERE THAN I BELIEVE THERE ARE SOME SCREW UYNDER IT THAT NEED TO COME OUT THEY WOULD BE BEHIND THAT MIDDLE PIECE I SAID YOU FIRST NEED TO REMOVE...
    I CANT REMEMBER THE SPECIFIC LOCATIN FOR TYPE S THOUGH BECAUSE ITS BEEN 3 YEARS SINCE I TOOK MY FACTORY SHIT OUT..
    GOOD LUCK.. ITS REAL EASY THOUGH
    Lawrenceville, GA
    THANKS MAN... I'LL GIVE THAT A TRY.
    Nope 4spauto's Avatar
    Around the Corner
    Lawrenceville, GA
    THANKS MAN... BOTH WERE PRETTY HELPFUL.
