Results 1 to 5 of 5
Thread: Steering Problems
    NE GA
    Default Steering Problems
    I've already searched and did not find what i was looking for... so no stupid comments.
    My car (00 civic) hit a curb on the front driver side and now the steering is going bad to the left. Also, when i put some 17's on the car, the rim is a lot closer towards the back of the fender than it is to the front bumper. howver, on the passenger side, the rims sit perfectly normal in the center. so when i turn left, there is a lot of rubbing going on. so i can only drive on 15s or smaller. i'm pretty sure it's not the alignment and is something bigger but i don't know what it is. anyone have any suggestions before i take it to the shop and pay an arm and leg? let me know what it is so that i can hopefully fix by myself. Thanks
    Gainesville
    you warped your shit.. best bet is to take it to a tire shop and let them fix what it broke and /or bent
    70hp FTL StraightSix's Avatar
    Central, SC
    Sounds like bent suspension parts to me. You'll have to get the car in the air and inspect everything. I would check the straightness of the control arm, first. Check to see if any of the cross members have moved, too.
    Oct 2003
    check lower control arm..bushings and upper..tension rods
    Probably bent lower control arm.
