Results 1 to 38 of 38
Thread: Diesel fuel in my Yaris...
    Kennesaw, Ga
    Default Diesel fuel in my Yaris...
    Went to fill up yesterday morning and some jack@ss had crossed the 87 octane pump and the diesel pump. Being in a hurry, I didn't even check to see where the hoses were running and thus, pumped about a gallon and a half of diesel in my car before realizing what I was doing. Yeah, I feel dumb so don't start.
    So here's my dilemma. My gastank holds a little over 10 gallons. After pumping in a gallon and half of diesel, I quickly swapped over and proceeded to fill the rest of the tank with 93 octane premium fuel. Will this dilute(sp?) the fuel enough so that it doesn't cause any serious problems? The car has already stuttered a bit on the road and when taking off in first gear. No smoke yet, so I'm hoping that's a good thing. Anyone got any advice other than changing the fuel filter here in a little bit? I'm already going to do that. Thanks.
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    I would drain the tank, a few dollars of fuel is not worth damaging anything on that car
    2006 Evo IX - Bolt ons
    LAWRENCEVILLE
    IT will be alright but I would run it out! but you would be in trouble if it was the other way around gas in a diesel FTL
    Belview Insane Asylum
    Say goodbye to your cat and possibly your O2 sensors.
    How do you not notice that you are grabbing a diesel pump?
    why did u start the car and continue driving? i wouldnt risk running diesel in my car.
    In America the diesel filler nozzle won't fit in a gasoline hole...
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    ya thats what i thought..
    x3. That's what I thought.
    Are you sure it was diesel?
    ***Lotus Elise***
    BlackWatchRacing
    Kerosene FTW!!! Guaranteed to have the cleanest fuel line in Atlanta, hahaha.
    j/k, those are normally completely seperate pumps
    Kennesaw, Ga
    Quote Originally Posted by BenefitX
    I had to be somewhere important. I called some other car buddies and they said to dilute it as much as possible. It's running okay right now, just a little hesistant. Hopefully it'll run itself through for a bit and then I'll swap the fuel filter.
    i would run some fuel injector cleaner too
    Quote Originally Posted by Ran Kizama
    Why risk anything happening? Drain it. Get a 2 gallon tank fuel of fuel to put in it afterwards, and then fill it up.
    It seems reasonable to me. But I may be overlooking something, so that may not be a good idea.
    ***Lotus Elise***
    BlackWatchRacing
    Certified Gearhead ruffriderGA's Avatar
    at most gas stations diesel pump is bigger in diameter and wont actually fit in a regular car, sometimes it hardly fits in our diesel you have to hold it there
    Quote Originally Posted by ruffriderGA
    Kennesaw, Ga
    Seemed to fit with no problem at the Shell station.
    'Round These Parts
    Thanks for the info, I'll buy your yaris for 1500.00 right now!
    LOL
    Leisa and S. 4 Life NM?
    But the fuel nozzle itself is usually green! Stupid!
    Haulin A$$!!!!! BigPoppaHurtm's Avatar
    In my dreams.....
    My dad did this same thing at the chevron years ago. the diesel pump was built in next to the regular stuff and he filled the whole tank full of it. The dealer charged 400+ to clean the entire fuel system.
    Quote Originally Posted by GIXXERDK
    If it took a whole thread to figure out how to hide from ricers, you're a dumbass.
    Oct 2003
    isnt fuel injector cleaner almost deisel ..smells like it.....
    Kennesaw, Ga
    Yeah...I know this now.
    Anywho, the car seems to be running fine now. A little sluggish as expected, but no engine codes or sputtering. I'll keep putting premium in for the next couple of tanks just to be sure.
    just put some water in there to rinse out the diesel...
    Woodstock
    i heard sugar will help with that also...
    Val RIP
    my only rule in life
    Kennesaw, Ga
    Actually, I just threw a penny in there. I hear the copper counteracts the effects of diesel.
    RIP
    wherever
    ummmm, good chance of killing O2 sensors and converter. But it shouldnt mess anything else up, maybe foul the plugs. With that little diesel in there, i'd let it get to like 1/2 talk and fill it back up. The worst thing you could have done is put 93 in there. Octane rating has NOTHING i repeat NOTHING to do with "diluting" diesel. If anything, you just made it worse.
    See, you have to understand how fuel works, which Nate, apparently you don't, so here's your crash course.:
    Octane rating refers to how quickly the fuel ignites- the lower the rating, the faster it ignites. A higher octane means it takes more direct heat (ie- spark) to ignite the fuel. That's why you use 93 in high compression and boosted cars, because the heat of the intake and compression CAN pre-ignite the fuel (ping,knock etc...) Now, since diesel engines don't have spark plugs, the diesel doesn't use a ignition source. The diesel basically works off detonation. They have very high compression ratios that compress so much, the diesel self ignites and makes combustion. Now mixing a substance that takes a LOT of heat to ignite and mixing it with a gasoline that has a higher threshold before ignition is going to be your problem. If you would have filled up with 87, you'd pretty much not have anything to worry about. But with that 93 you are going to feel the car running like ass.
    02' Miata
    He speaks the truth. I would change the plugs and the fuel filter. But I think you may have took a few miles off the life of that engine. It may have gummed up the valves in it a little. I am also pretty sure that diesel has some sort of solvent in it in the u.s. Like a soap kind of sort of that keeps the fuel system clean. I would just do what I said then pray for the best. thats my 2cents.
    Kennesaw, Ga
    Quote Originally Posted by DropTopDrifter
    Thanks for the info.
    Yeah, I already planned on swapping the plugs and fuel filter. I'll run a few bottles of cleaner through it later on too.
    Jeez Ran you are sucha noob. You still moving to Japan? If so can you overnight me parts?
    ***Lotus Elise***
    BlackWatchRacing
    Kennesaw, Ga
    1) Yes, still going to Japan.
    2) You drive a VW. Why do you need parts from Japan?
    3) Car is running fine right now.
    1. Cool.
    2. But I wanna get overnight parts from Japan. Jeez.
    3. You're a liar.
    ***Lotus Elise***
    BlackWatchRacing
    Kennesaw, Ga
    3. You're a liar.
    Seriously, it's running about the same as it used too right now. The Yaris can pretty much run on horse piss so I guess that helps.
    SoooperDooooperLS
    LoL, isnt the nozzles different sizes????
    Ran if you goto Japan see if you source some JDM foglights for Yousef....damn bastard keeps annoying me with that. And while your at see if they have Type S seats there.
    Banned Z32redondo's Avatar
    Columbus, GA
    93 FTW...Got to use it in my Z or it gets sluggish.
    In the Fucking A
    Just throw that Yaris away and buy another one
    I fucked ©hris's mom
    G-net
    Quote Originally Posted by Big Baller
    i thought the Yaris was a one time use only anyways
    Domestic Power R.Kelly's Avatar
    Stockbridge
    i know if a motor is already warm it will usually run on diesel
    In the Fucking A
    Drain the tank
