Results 1 to 16 of 16
Thread: WtB camaro rear end!!!!!!!!!!!!!!!!
    LAWRENCEVILLE
    Default WtB camaro rear end!!!!!!!!!!!!!!!!
    I know this is not the best place to look but I need a rear end for my mothers 99 camaro. the car is a v6 auto but I will also take a v8 rear end I need this asap!
    Hella stock member!
    __DailyGrind
    damn..i got the entire Passenger Quarter cut...lol....send me some of ur damages and i see if i have wat u are looking for
    Oct 2003
    you mean axle or rear body part?
    LAWRENCEVILLE
    sorry I ment rear axle!
    Oct 2003
    IF YOU NEED IT FOR THE REAR DIFF, I GOT ONE...MINE HAS A BAD PASSENGER OUTER BEARING/POSIBBLY BENT FACE TO SHAFT.....LIMITED SLIP FROM MY 1996 LT1 6SPEED
    $150
    LAWRENCEVILLE
    Quote Originally Posted by Annihilation
    $150
    I dont need one with the same problem as mine
    your moms house
    will a blazer rear end work?? ill see what i can do since we have a couple work blazers here and a few s10's...LMK man
    FUCK B&D COMMUNICATIONS!
    LAWRENCEVILLE
    Quote Originally Posted by Steveo
    i dont think so
    Woodstock
    Thats 10 bolt rear right? Swap the brakes and it might fit. Just axel length difference
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Senior Member jfman's Avatar
    Quote Originally Posted by Blitanicle99
    Not the same blazers have leaf springs and camaro have regular spring torque arm/panhrd bar setup.
    No other rear end than an F-body rear end will fit.
    LAWRENCEVILLE
    anyone I need this asap!
    JDM TYTE AnthonyF's Avatar
    car-part.com try there
    The Carbon Fibered R6
    Woodstock
    Ok well take the set up off your axel and cut the leaf spring brackets off the blazer axel with a torch. Weld on the new setup on the blazer axel. It sounds far fetched but it works.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    LAWRENCEVILLE
    way to much butchering for me I think I am going to just get the stock rear end fixed
    go to pull a part
    LAWRENCEVILLE
    Quote Originally Posted by santacruz77
    go to pull a part
    they dot have any
