Results 1 to 28 of 28
Thread: VG30DETT swap 240
    Default VG30DETT swap 240
    has anyone heard of a VG30DETT swap into a 240. im thinking of doing it but not alot of info on it. any advise:boobies:
    TopSecret
    Cobb County
    it's been done, but they say its very difficult, check out this website to see what they say about it
    http://klohiq.tripod.com/cars/240sx/swap.html
    Coming Back...................................
    Supraforums.com
    EastCoastBoost
    Dunwoody, GA
    G/L man, if you get it done, i'd love to see that. i've heard of people doing it; but i've never actually seen one done.
    lolol, have you ever worked on a VG30DETT? (or even a VG30DE)
    Senior Member Krazykouki's Avatar
    Ball Ground
    All I can say is dont do it...lol...9/10 swaps attempted never run.
    No Homo.
    Gainesville
    lol my ex g/f altima had a VG30de
    Quote Originally Posted by §treet_§peed
    i don't think so
    ...j30's had a tuned down version of the VG30de's but altimas are front wheel drive.
    Gainesville
    dude i shit you not... even when she took it up to the dealership to see if it rly was.. no shit
    a FWD VG30DE 3.0 liter V-6???
    Haulin A$$!!!!! BigPoppaHurtm's Avatar
    In my dreams.....
    Your better off with a rb25 or 20. If u got big bucks then 2j is the way.
    Quote Originally Posted by GIXXERDK
    If it took a whole thread to figure out how to hide from ricers, you're a dumbass.
    Banned Z32redondo's Avatar
    Columbus, GA
    Stay away from them unless you absolutely have to have one (a 300). I have a pretty large engine bay and to do ANYTHING beside intake or something siple you have to pull the engine. I would not even attempt it. Just 2JZ
    20 side of thangs
    dont waste your money if you cant do it yourself. so many other alternatives that will achieve better results. 2jz is my choice.
    Gainesville
    yeah no shit.. thaqt's what i was like when i first saw it
    They had KA24's at one time transversely mounted but i'm pretty sure never a VG30DE. Didn't they go from the 2.4L to a 3.5?
    wherever
    you idiots. Older Altimas had a KA24DE. Maximas had VG30E and later/newer altimas had the VQ35. J30 had a VG30DE.
    VG30ET>VG30DETT as far as maintenance.
    02' Miata
    wherever
    Quote Originally Posted by NSCredondo
    The older Z31 VG30ET was pretty easy to work on. That in a 240 would probably be pretty good as i have seen those motors make 300-400hp on stock internals and 500+ on a built car. You can stroke it to a 3.3L too... thats a nasty motor
    02' Miata
    Quote Originally Posted by DropTopDrifter
    That's what i said
    wherever
    you failed to mention that it was the MAXIMA that was the FWD VG30......
    My post was more informative
    02' Miata
    It's not a DE so it didn't matter Plus V6 & v8 FWD's are the most ridiculous thing ever invented.
    wherever
    Ahhh, but there was a VG30DE in the Maxima.....
    02' Miata
    nope
    VG30DE
    1990–1996 Nissan 300ZX
    1987–1999 Nissan Fairlady Z
    1988 Nissan 200zx (similar chassis to the 300zx, different panels
    1993–1998 Infiniti J30 and Nissan Leopard J. Ferie
    1992–1995 Nissan Gloria and Cedric
    1989–1991 Nissan Cima
    VG30E
    1984–1989 Nissan 300ZX/Nissan Fairlady Z
    1987–1988 Nissan 200SX SE
    1984–1994 Nissan Maxima
    1990–1991 Infiniti M30/Nissan Leopard
    1990–1996 Hardbody Truck
    1990–1995 Nissan Pathfinder/Nissan Terrano
    1992–1999 Nissan Gloria/Nissan Cedric (179 hp)
    1992–1995 Nissan Quest/Mercury Villager (modified to become a non-interference design)
    wherever
    Excuse me, the Maxima DID have a 3.0L with a dual cam head....
    The VE engine is a 3.0 L V6 piston engine from Nissan. It is based on the Nissan VG engine and was only used for the '92, '93, and '94 model years. This engine has an iron block, aluminum cylinder heads with 4 valves per cylinder and dual overhead camshafts, variable valve timing on the intake camshafts, coil on plug ignition, and an available variable intake manifold. (5spd only)
    A major difference between the VE30DE and the VG30DE engine is the heads. The low underhood clearance on the 1992–1994 Maxima demanded a special head to be developed with 30°, rather than 46°, between the valves. Lack of space also demanded a redesigned camshaft drive system, so a special chain drive was developed. The engine is otherwise similar to the VG30DE.
    The 3.0 L (2960 cc) VE30DE produces 190 hp (142 kW) at 5600rpm and 190 ft.lbf (258 Nm) at 4000rpm. This engine redlines at 6500rpm. It was built from July, 1991 through March, 1994.
    It is used in the following vehicle:
    * 1992-1994 Nissan Maxima SE
    02' Miata
    Doesn't matter if it was a quad cam, rotary, or a radial....it didn't have a VG30DE, it was a VG30E & VE30DE
    wherever
    oohhh.. the block was the same, just had different heads
    VE V-6 DOHC
    4 Valves per cylinder
    Variable timing control
    3.0L Aluminum/
    Iron Direct Ignition 1992-1994
    Maxima SE
    190/190 Similar block to VG series.
    A lame duck engine, at least in the States.
    Used only for three years in the Maxima SE.
    Variable intake runners and (problematic but fixed in 94).
    variable timing control.
    02' Miata
    VE V-6 DOHC
    3.0L Aluminum/
    Maxima SE
    my '90 Z32 VG30DE had variable timing...a year before VTEC!!
    Gainesville
    whoops it was a Maxima lol Pwn my self on that one lol
    Gainesville
    vg something lol prolly the vg30e
