Results 1 to 10 of 10
Thread: New clutch question
    Acworth
    Default New clutch question
    I just installed a stage 3 6 puck clutch in my 92 240 sx ka-t and i was expecting it to work right away but it tried it out and it still slips.. Ive just adjusted the pedal but i dont think its going to help much and was wondering about the break in period. I think it said 500 miles so should i expect it to slip until it broken and just drive it easy or should i be concerned? Its slipping when i make full boost and my car is only making around 240hp..
    My Spoon Is Too Big! Flip's Avatar
    Did you resurface your flywheel?
    EastCoastBoost
    Dunwoody, GA
    Flip???
    hey man, you still got that integra??? I used to come over to your house with that crazy russian. Lexy
    Acworth
    Quote Originally Posted by Flip
    Yes i had the flywheel done with the clutch
    Acworth
    also i adjusted the rod on the pedal almost all the way with most of the threads on the pedal side instead of the firewall side.
    no strange noises like the disc or pressure plate isn't seated properly?
    Oct 2003
    did u get a heavy duty pressure plate or did you use a stock one?
    Gainesville
    ^ good point
    Senior Member Krazykouki's Avatar
    Ball Ground
    when you break in a clutch you dont let it go into full boost because you are not supposed to go all out on it. There is a break in period for a reason.
    No Homo.
    Gainesville
    first 500 or so miles is the proper break in period
