Thread: 90 da axles in a 90ef / b16a swap
    random guy's pops!
    random guy's moms cornhole!
    Default 90 da axles in a 90ef / b16a swap
    i bought the da axles because i read that they would fit ,when i got home i tried to put them in the hub from the outside just to see if they would fit , it was a no go , the da axles splines wouldnt go into my hubs the end of the axles wouldnt fit in the hole(i did get the da axles non-abs) any suggestions? , thanx fellas!
    dnwp
    350Z and Fit Pilot...FTW
    Fayetteville
    "da"=the
    so confusing
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by RoadsterFit
    "da"=the
    so confusing
    no
    da = 90-93 integra
    damn noob
    \m/>_<\m/ dorin48's Avatar
    Canton
    Double check the part numbers and compare to another set. Mix ups happen all the time, where did you source the axles?
    random guy's pops!
    autozone
    dnwp
    Augusta, GA
    i do know with my little knowledge about ef's, that the STD model needs new hubs with a b-series motor, cause of the splines on the axle won't fit in it. but not sure on what model you have
    random guy's pops!
    dx
    dnwp
    Canton
    ah there is the problem. ur a dx need new hubs. g/l with that
