Results 1 to 2 of 2
Thread: Suspension Problem
    Default Suspension Problem
    Can a improperly installed Tie rod end cause you wheel to wobble only in reverse?? I installed my new suspension the other day. IN the process I broke a tie rod end. No biggie, just bought a new one from honda. But now my wheenl wobbles when I back up. I'm going to get my car aligned in the morning, and that might solve the problem, but does anyone else have any other suggestions?? I probablly fucked up on the tie rod end install and didn't tighten it down enough.
    Yeah man. Fr33way's Avatar
    North OTP
    I will just say that tie-rods can lead to wobbling/vibration for sure. Assuming all other bolts are torqued to spec that may be your problem. Did you get it aligned? Toe could be all fucked up as well.
